Local Time 16:15 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Gutenberg v.95
Goksteroo
Posted: 01:06am 02 Nov 2021
Oops... have to update this a bit too soon after initial release. I had tested the original release using all sorts of modes and font combinations and then added some more functionality. This messed up some of the displays in certain modes/fonts. The main issue was the way the MODE command works - resets the font to the system font, will not clear the screen if already in that mode but does reset the font.
Anyway, while I was at it, I added some more little bits including..
Mode and font for menu and reading are set by editing the first 4 lines of code. Values are displayed on loading screen.
The colour schemes are now an #include file that can easily be edited as you see fit.
Biggest issue now is the pause in the system when the mode command is used to actually change the mode. I can't see a way around this. No issue if menu and read mode are the same.
Enjoy... does run smoother now and as initially intended.
Geoff - aka goksteroo
gutenberg_95.zip
