Local Time 16:14 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite ' PLAY VOLUME ' .....
hitsware2
Posted: 12:43am 31 Oct 2021
....Seems to not affect either the PLAY SOUND or PLAY TONE outputs ?
my site
Posted: 09:00am 31 Oct 2021
Play sound uses individual volumes on each sound 0-25
play volume works on play tone
In both cases the modification is linear so you have to make a much bigger change than you expect. Try play volume 5,5 and you will hear a difference.
I've just checked on the scope and the commands are working as expected
hitsware2
Posted: 12:36am 01 Nov 2021
Yes ... Thank You ..... That is how it is working ..
I must have been dreaming of a ' master volume '
Right after dreaming the wave shape letters could be
variables ( that would really help a lot )
Did You put together the MMBasic ' SOUND ' system ?
my site
Posted: 07:52am 01 Nov 2021
  Quote  Did You put together the MMBasic ' SOUND ' system ?
Yes. Note the latest beta where I have implemented a log curve on the volume controls
hitsware2
Posted: 10:04am 01 Nov 2021
  matherp said
Yes.
I sincerely bow to You
The closest thing I have found
( as far as Basic with musical capability
( and I have looked for decades ) )
is BBCBasic .
Would You please explain one more time
why the waveshape parameter cannot be
a variable ?
my site
Posted: 08:26am 02 Nov 2021
See V5.07.01b3
hitsware2
Posted: 07:37pm 05 Nov 2021
  matherp said  See V5.07.01b3
Rem :       WORKS LIKE A CHARM !... :)
Dim i$(3)
Data s,q,w,t
For x=0 To 3
Read i$(x)
Next x
For y = 0 To 3
Print "y=";y;"    ";"voice= ";i$(y)
Play sound 1,b,i$(y),300,25
Pause 2000
Next y
my site
