Local Time 16:15 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite ' CLS '
hitsware2
Posted: 05:55pm 27 Oct 2021
CLS
Gives me
Saved 30 bytes
[3] CLS
Error : Display not configured
I have not been able to find how
to configure . ( It does ' PRINT ' )
my site
Posted: 06:01pm 27 Oct 2021
CLS is a graphics command. It works when you have an LCD screen enabled
OPTION LCDPANEL .......
Or am I missing something?
Posted: 07:05pm 27 Oct 2021
You probably want to do:
Print Chr$(27) + "[2J" + Chr$(27) + "[H"
which will mimic a CLS on a VT serial console.
hitsware2
Posted: 07:24pm 27 Oct 2021
  matherp said  CLS is a graphics command. It works when you have an LCD screen enabled
Normally it would clear the screen :
CLS [colour] CMM
              MM
             DOS
Clears the video display screen and places the cursor in the top left
corner. Optionally 'colour' can be specified which will be used for the
background when clearing the screen (Colour Maximite only).
my site
hitsware2
Posted: 07:27pm 27 Oct 2021
  thwill said  You probably want to do:
Even though it will ' PRINT ' ,
it won't ' CLS '  ????
my site
Posted: 07:33pm 27 Oct 2021
  hitsware2 said  Even though it will ' PRINT ' ,
I'm not going to argue the right and wrong of it, but PRINT is a "console command" (I'm guessing it doesn't print to the LCD, you use TEXT for that) whereas on the PicoMite CLS is a purely "graphics command".
Edited 2021-10-28 05:33 by thwill
Posted: 07:37pm 27 Oct 2021
CLS brings up an error if used on the terminal. It's a graphics only command and will only work on attached LCD display.
  Quote  Saved 30 bytes
[3] CLS
is telling you that you have no LCD display configured.
To configure one you'll have to connect it and use the appropriate OPTION LCDPANEL command for that model. Have you got one attached?
Note that on the PicoMite the Console and Graphics commands are completely different and non-interchangeable. There is a reason for this. The PicoMite is intended to be used as an embedded controller, where the user's interface would be via a touch screen or similar. Allowing the user to connect via the Console could be dangerous (or at least damaging). Consequently the Console and LCD modes are completely separate. The PicoMite will run perfectly happily without a console attached.
Edited 2021-10-28 05:51 by Mixtel90
Posted: 07:58pm 27 Oct 2021
Another way of looking at it is "Do you really want the act of clearing the LCD to also clear all those debug/diagnostics you were PRINTing to the terminal ?"
hitsware2
Posted: 08:45pm 27 Oct 2021
  thwill said  Another way of looking at it is "Do you really want the act of clearing the LCD to also clear all those debug/diagnostics you were PRINTing to the terminal ?"
"Do you really want all those debug/diagnostics
you PRINT to the terminal to scroll rather than
refresh ?"
my site
hitsware2
Posted: 08:47pm 27 Oct 2021
Thank You !
Awkward , but it works ....
my site
Posted: 09:09pm 27 Oct 2021
I posted a little VT100 library a while ago. It has various commands to control the console, so Vcls clears the screen Vch sends the cursor home Vat(row,column) moves the text position to a set point - like Print@ but it doesn't accept a string. There are also commands to change the foreground and background colours and a bit more stuff. It was intended for the Micromite, but seems to run fine on anything.
Tinine
Posted: 09:44pm 27 Oct 2021
Here it is....
Thanks Mick
Posted: 07:36am 28 Oct 2021
I found a bug in it a couple of weeks ago. I think it was to do with text attributes not returning to normal or something. Can't remember what I was doing now...
There are probably others. :)
