Glen0 Senior Member Joined: 12/10/2014 Location: New ZealandPosts: 102
Posted: 12:09am 22 Oct 2021
Trying to use up the 2 Snadpics I aquired a long time ago. Could someone please point me to where I can find info on using these with MMBasic. I recall seeing it discussed quite a lot in the early days on a few threads but I have not been able to find them. Much appreciated ( in advance)
led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 210
Posted: 01:41am 22 Oct 2021
Try in your favourite search engine:
Heaps of responses using DuckDuckGo ledMiss you George
Posted: 09:49am 22 Oct 2021
Cheers, that's it. found it in the mm extreme manual. forgot about that.
Phil23 Guru Joined: 27/03/2016 Location: AustraliaPosts: 1667
Posted: 09:05am 26 Oct 2021
I thing the MM+ manual would be more applicable. Basically it's the same chip as in the E100.
See https://geoffg.net/micromite.html
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11890
Posted: 10:03am 26 Oct 2021
The snadpic was available with various different processors. I used one to develop the MMX. If the processor is a MZ then you need the MMX firmware
