Local Time 16:30 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LINUX: Volume issues....
Posted: 08:08am 18 Oct 2021
Hi all.
1) 2TB ext4 volume, perfectly accessible, e2fsck -f /dev/sdd1 completes without any errors at all.
2) Move this volume OUT of the PC, and plop it into an external USB3 dock.
3) Linux REFUSES to ACCESS it at all, no matter what.  I CAN see the drive in disks, but as an unformatted 2TB volume, which I know is wrong.
Not being dumb enough to just reformat the volume, I put it back in the Linux PC, and it can be accessed fine.
So, my question is: HOW MANY USB3 EXTERNAL DRIVE DOCKS are actually Linux aware?
It would seem I  have one that flatly refuses to talk to Linux volumes.
It can see Windoze volumes just fine - even if I plop one into it under Linux, it sees it as an NTFS volume, but the ext4 drive from the Linux PC - "Sorry, I can't see you. :("
Anyone else seen this?
Posted: 09:21am 18 Oct 2021
I don't have any such docks but maybe dmesg when you plug it in will help?
Posted: 07:56am 19 Oct 2021
I tried the same dock under Linux Mint, but the same result.
The system DOES see the drive, but as an unformatted 2TB volume.
The drive is an WD Red NAS drive with "NASware 3.0" firmware.
Could it be possible that these drives simply don't support or allow connection to a dock or other USB adaptor, and that they MUST be connected to a SATA host on a mainboard?
That's about all I can think of now.
Posted: 04:12pm 20 Oct 2021
I can't see why (or why not - sorry).
What does dmesg show?
After plugging thee drive in you can do something like
dmesg | tail -12
just to get the few lines about the drive.
I've more ideas but they depend on that...
Edited 2021-10-21 02:13 by JohnS
Posted: 07:16am 21 Oct 2021
Hi John.
Thanks for your continued interest.
I would have posted the results of a dmesg, but as of tonight, I built a new temporary Puppy Linux Bionic x64 box, connected the problem drive, and Puppy sees it just fine, so I am in the process of copying everything from it, to the new 4TB drive in another server box.
Once complete, I can certainly put the drive back into an external dock, and run that command and see what is reported.
Posted: 07:59am 21 Oct 2021
Hey no worries - especially if it's working :)
