Local Time 16:01 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBASIC Error Line Number?
toml_12953
Posted: 06:27pm 17 Oct 2021
The following program ends with "Error in line 16: No DATA to read"
Shouldn't the error be in line 5?
90 PRINT
95 PRINT "PRIME DEN";@(120);"LEAST EXP"
97 PRINT "##### ###";@(120);"##### ###"
99 PRINT
100 READ D
105 IF D=5 THEN 100
110 LET X=10
120 LET N=1
130 LET X=INT((X/D-INT(X/D))*D+.5)
140 IF X=1 THEN 180
150 LET X=X*10
160 LET N=N+1
170 GOTO 130
180 IF N=D-1 THEN PRINT D;" **";@(120);N
181 IF N<>D-1 THEN PRINT D;@(120);N
190 GOTO 100
260 DATA 3,5,7,11,13,17,19,23,29,31,37,41,43,47,53
270 DATA 59,61,67,71,73,79,87,89,97
280 END
Posted: 06:54pm 17 Oct 2021
I am assuming you are om a Maximite (the @ prints needed tweaking to run on my desk micromite with 5.0408)
However...
> RUN
PRIME DENLEAST EXP
3 1
7 ** 6
11 2
13 6
17 ** 16
19 ** 18
23 ** 22
29 ** 28
31 15
37 3
41 5
43 21
47 ** 46
53 13
59 ** 58
61 ** 60
67 33
71 35
73 8
79 13
87 28
89 44
97 ** 96
[5] 100 Read D
Error: No DATA to read
as expected I believe? so something peculiar to the flavour of MMBasic you have - more details?
Edited 2021-10-18 04:56 by CaptainBoing
toml_12953
Posted: 01:26am 18 Oct 2021
  CaptainBoing said  I am assuming you are om a Maximite (the @ prints needed tweaking to run on my desk micromite with 5.0408)
However...
> RUN
PRIME DENLEAST EXP
3 1
7 ** 6
11 2
13 6
17 ** 16
19 ** 18
23 ** 22
29 ** 28
31 15
37 3
41 5
43 21
47 ** 46
53 13
59 ** 58
61 ** 60
67 33
71 35
73 8
79 13
87 28
89 44
97 ** 96
[5] 100 Read D
I'm running MMBasic 5.07.01 on a 504MHz Colour Maximite 2 G2
Tinine
Posted: 01:27am 18 Oct 2021
IF X=1 THEN 180
This is legal?
Damn, as huge fan and defender of the BASIC language, even I regard this listing as plain offensive
Posted: 05:36am 18 Oct 2021
  Tinine said
IF X=1 THEN 180
This is legal?
In many BASICs, no.
(You'd have to use GOTO instead of, sometimes as well as, THEN.)
In others, yes. Ugly.
Edited 2021-10-18 15:38 by JohnS
Posted: 06:01am 18 Oct 2021
Early computers had no room for excess verbosity. If it works it's perfect.
Posted: 06:18am 18 Oct 2021
It is legal in MMBasic although depreciated.
Posted: 08:43am 18 Oct 2021
Looking at MMB4L it shares the same issue (and 99% the same code), it looks like following a GOTO may not update "CurrentLinePtr", which thus still points at the line containing the GOTO statement - it's a bug, nothing that you are doing wrong.
Posted: 08:53am 18 Oct 2021
Looks like a core MMBasic issue. One for you Geoff?
480MHz Colour Maximite 2 G2
MMBasic Version 5.07.02b1
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> list "goto_test.bas"
10 Print "Hello"
20 Goto 30
30 On Error Skip : Error "foo" : Print Mm.ErrMsg$ + " -- should say line 3"
40 Gosub 60
50 End
60 On Error Skip : Error "foo" : Print Mm.ErrMsg$ + " -- should say line 6"
70 Return
> run "goto_test.bas"
Hello
Error in line 2: foo -- should say line 3
Error in line 4: foo -- should say line 6
Edited 2021-10-18 19:10 by thwill
toml_12953
Posted: 10:32am 18 Oct 2021
  JohnS said
  Tinine said
IF X=1 THEN 180
This is legal?
In many BASICs, no.
It is legal in most '70s and '80s BASIC interpreters.
IF X=1 THEN 180
IF X=1 GOTO 180
IF X=1 THEN GOTO 180
were all legal.
Edited 2021-10-18 20:33 by toml_12953
Posted: 12:05pm 05 Nov 2021
  thwill said  Looking at MMB4L it shares the same issue (and 99% the same code), it looks like following a GOTO may not update "CurrentLinePtr", which thus still points at the line containing the GOTO statement - it's a bug, nothing that you are doing wrong.
Peter, Geoff, it looks like the fix is simple as adding:
CurrentLinePtr = nextstmt;
to the end of cmd_goto() and cmd_gosub().
There is however another issue in that TRACE won't log a visit to a line that you GOTO or GOSUB using a line number (but will if you use a label):
> list "trace_test.bas"
Trace On                       '  1
                               '  2
GoSub 10                       '  3
GoSub label                    '  4
End                            '  5
                               '  6
10 Print : Print "Hello"       '  7
Return                         '  8
                               '  9
label: Print : Print "Goodbye" ' 10
Return                         ' 11
> run
[3]
Hello
[8][4][10]
Goodbye
[11][5]
Observe how visiting line 10 is logged, but visiting line 7 is not.
