Local Time 16:29 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Font 7 bug or manual error?
Goksteroo
Posted: 02:25pm 12 Oct 2021
I've been working on a little programme that should(!?) work in any resolution/font combination. Font 7 gave me very unexpected results during testing. The manual states font 7 is a 6x8 font and mm.info(fontheight) and mm.info(fontwidth) gives these same values. During testing font 7 seems to actually be a 6x10 font on screen. I am using a the latest beta firmware. Is the mm.info(fontheight) returning the wrong value or has the firmware changed the way font 7 is displayed?
Posted: 02:41pm 12 Oct 2021
Which 'Mite?
Goksteroo
Posted: 02:47pm 12 Oct 2021
Oops... CMM2 G1
Edited 2021-10-13 00:48 by Goksteroo
Posted: 05:05pm 12 Oct 2021
Font 7 is 6x8. You can use it in a program with the text command or the print @ command to space it at 8 pixel height. The normal print command, the editor and the filemanager space font 7 at 10 pixel height for readability
