Local Time 16:43 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Bug with LOC() or user failure ?
Posted: 08:58pm 07 Oct 2021
What do we think of this one ?
> 480MHz Colour Maximite 2 G2
MMBasic Version 5.07.01
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> list "loc_test.bas"
Open "foo.txt" For Output As #1
Close #1
Open "foo.txt" For Random As #1
Print Loc(#1) ' Should be 1
Print #1, "foo";
Print Loc(#1) ' Should be 4
Close #1
Print Loc(#1) ' Should be 4 if the DOS code is a good reference
Close #1
> run "loc_test.bas"
0
0
0
Posted: 09:43pm 07 Oct 2021
void fun_loc(void) {
int fnbr;
getargs(&ep, 1, ",");
if(argc == 0) error("Syntax");
if(*argv[0] == '#') argv[0]++;
fnbr = getinteger(argv[0]);
   if(fnbr == 0)                                                   // accessing the console
       iret = kbhitConsole();
   else {
       if(fnbr < 1 || fnbr > MAXOPENFILES) error("File number");
       if(FileTable[fnbr].com == 0) error("File number is not open");
       if(FileTable[fnbr].com > MAXCOMPORTS) {
//            if(fmode[fnbr] & FA_WRITE){
//                iret = (*(FileTable[fnbr].fptr)).fptr + 1;
//            } else {
//             iret = RoundUptoBlock((*(FileTable[fnbr].fptr)).fptr)  -511 + buffpointer[fnbr];
       } else iret = SerialRxStatus(FileTable[fnbr].com);
   targ = T_INT;
WTF?
Posted: 07:36am 08 Oct 2021
When fixed, shouldn't it be
0
3
3
Posted: 07:45am 08 Oct 2021
  JohnS said  When fixed, shouldn't it be
0
3
3
It's indexed from 1 according to the manual ... and also according to MMBasic for DOS source code.
Posted: 09:10am 08 Oct 2021
Commented out one too many line. Will be fixed in next release.
Thanks for the report
