Local Time 16:42 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GFXterm32 and GFXterm64, now including XModem support
Posted: 03:07pm 26 Sep 2021
see attached:
GFXterm32 and GFXterm64 (2021-09-27).zip
GFXterm source (2021-09-27) inc XModem support.zip
XModem support is accessed by pressing F11 ("load") or F12 ("save") at the MMbasic command prompt. the process is pretty much fully automated, i've tested it works with both an MX170 and a Pico.
as before, please test, test, test. and if anyone wishes, feel free to upload a build for RPi or macOS. or even better, finish off making the win32 build fully functional!
rob   :-)
led-bloon
Posted: 09:21pm 26 Sep 2021
GFXterm(2021-09-27) for Raspberry Pi Buster 32bit OS
GFXterm-armhf.zip
Rob
Nice to see the final line "cleaned up" when using xmodem for text files - NO spurious NULL characters!
led
Edit: Added Shortcut-keys pdf file to zip file, removed binary file comment.
Edited 2021-09-27 09:14 by led-bloon
Miss you George
Posted: 05:15pm 07 Oct 2021
small(ish) update:
GFXterm32 (2021-10-08).zip
GFXterm64 (2021-10-08).zip
assuming i've got the right files in the zip archives, changes include:
- a fix for problems with pasting into the micromite's editor for older versions of MMbasic dating from 2018 and earlier,
- the 'CONNECT...' dialog now shows the serial parameters, default "8-N-1". right-click on this string to change between 7/8 bits, odd/even/no parity, 1/2 stop bits. settings are saved until a fail-to-connection, then revert back to 8-N-1.
- extended range of baud rates, now going up to 4,000,000 baud. these were added as i had need to connect to an android tablet at 921,600.
source code is in the GFXterm for windows thread, linked to here:
GFXterm source (2021-10-08).zip
led-bloon: are you able to compile for RPi? i did send you a PM a week or so back, but looks like it hasn't been opened.
rob   :-)
led-bloon
Posted: 09:36pm 07 Oct 2021
GFXterm(2021-10-08) for Raspberry Pi Buster 32bit OS
GFXterm32-armhf (2021-10-08).zip
Sri Rob for non-reply...
Just like brain, everything switched OFF here! Has been for years.
led
Miss you George
