Local Time 05:34 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : User Manual for the Picomite (draft)
     Page 1 of 5
Posted: 12:09pm 18 Sep 2021
We now have a User Manual for the Picomite (131 pages).  It is reasonably complete but undoubtedly will contain some errors.
You can download it from here:
https://geoffg.net/Downloads/PicoMite/PicoMite_User_Manual.pdf
It matches the current beta (Ver 5.07.00b19).
I would be grateful for any reports of errors, omissions, typos, etc.  If you find any please post them to this thread.
twofingers
Posted: 12:40pm 18 Sep 2021
Hi Geoff,
thank you so much, very appreciated.
(I wouldn't have dared ask about it.)
Thanks to Mick (Mixtel90) and of course Peter!
Best regards
Michael
Posted: 02:31pm 18 Sep 2021
Geoff,
A horribly quick glance through.
p7 add a space after screen (before /dev/...)
I can't test any of it but it looks great.
Posted: 09:03pm 18 Sep 2021
Hi Geoff,
Some feedback on the manual
- maybe add a note that while setting options, the usb connection is sometimes lost. Teraterm acts friendly and reconnects. Not all serial terminal emulators are so forgiving. Putty is not. You have to manually reconnect.
Page 8: the pico io pins cannot drive much current, maybe use a resitor of 470 ohm, not 82.
Page 10: not all pico s run at 250Mhz. That is why Peter changed the clock to a lower value default.
Page 119: the pulsin text contains reference to 40Mhz. 48Mhz is the minimum.
Thanks for writing this document..
Posted: 09:41pm 18 Sep 2021
Page 5 under "Terminal Emulator"
"Finally, the PicoMite ignores the baud rate setting so it can be set to any speed."
1200 baud will put the pico into firmware update mode so "any speed" is not correct.
palcal
Posted: 10:57pm 18 Sep 2021
For serial communication the manual says...
  Quote  SETPIN rx, tx, COM1
Valid pins are RX: GP1, GP13 or GP17
TX: GP0, GP12, GP16 or GP28
I have been using SetPin TX,RX and it works, so which is correct.
disco4now
Posted: 10:59pm 18 Sep 2021
The bookmarks expansions for Options,Commands,Functions,Obsolete Commands and Functions,Appendix A,B,D and E have all picked up a few unintended entries at the expanded level.
On page 47 in the BLIT command explanations, could the BLIT LOAD form be included as well.
Edited 2021-09-19 09:21 by disco4now
F4 H7FotSF4xGT
palcal
Posted: 11:14pm 18 Sep 2021
Using the command as per the manual...
  Quote  [20] SetPin GP1, GP0, COM1
Error : 0 is invalid (valid is 1 to 9)
Posted: 12:28am 19 Sep 2021
Thanks guys, I will fold the changes in.
@palcal:
You can define the pins in any order and the firmware will figure it out.  I think that is mentioned somewhere but I will check.
Peter?
panky
Posted: 02:21am 19 Sep 2021
P33 SD Card section - Connecting an SD Card , the GP number is missing.
P69 Option System I2C font?
Pages 87/88, 90/91, 98/99, 113/114 all appear to miss the bottom line/top line of the table  (Firefox browser ?)
PIO annex font?
Observations: Excellent Manual - thanks
The section talking about memory usage and the MEMORY function could perhaps be expanded to explain a little more on how memory is allocated, especially on the impact of GUI controls.
The function MEMORY could perhaps include number of GUI controls (if any)?
Doug.
palcal
Posted: 03:22am 19 Sep 2021
If it's of any help with my COMMS problem I have been using
  Quote  Open "COM1:9600" As #1
with pins 6 & 7 and it works OK. The manual says that is COM2
Posted: 07:14am 19 Sep 2021
palcal - Please check if you are using the latest version. I can't replicate your problems and they seem to be exactly what I would expect if you use the new syntax with an older version
Also note from the manual
  Quote  Note that the pins (eg, rx, tx, etc) can be declared in any order and that the pins can be referred to by using their pin number (eg, 1, 2) or GP number (eg, GP0, GP1).
Edited 2021-09-19 17:33 by matherp
palcal
Posted: 07:39am 19 Sep 2021
Ok, thanks Peter, will try tomorrow.
Poppy
Posted: 10:08am 19 Sep 2021
Great!
I did not recognize this little Thing until now.
Now I am going to get one for checking out!
Great effort!
THX!
Andre ... such a GURU?
palcal
Posted: 08:52pm 19 Sep 2021
I'll start a new thread.
Edited 2021-09-20 07:08 by palcal
Posted: 09:15pm 19 Sep 2021
  Quote  Problem is COM1 is receiving data meant for COM2.
Please can you try and provide a simple program that demonstrates the problem? I can't see anything in the code that could cause this issue so without something to test very difficult to fix
palcal
Posted: 09:23pm 19 Sep 2021
Oops I started a new thread where is it.
disco4now
Posted: 03:59am 20 Sep 2021
Hi Geoff,
These are mentioned in the TINMAN, not sure if you left these out by design or I just cant find them, but maybe useful somewhere around pages 9/10.
There are also four specialised I/O ports which, by default, are "wired" to pseudo-pins rather than wired out: They can be redefined, but this may not be safe on the PicoMite in some cases.
(41) GP23 is a SMPS control signal set to the value of OPTION POWER. (ON=PWM, OFF=PFM).
(42) GP24 is a digital input, which is high when VBUS is present.
(43) GP25 is also PWM4B. It is connected to the on-board LED.
(44) GP29 / ADC3 is an analogue input connected to a potential divider reading 1/3 of VSYS.
F4 H7FotSF4xGT
scruss
Posted: 12:00pm 20 Sep 2021
in manual as of Saturday 2021-09-18:
  Quote  By default the function keys will not be correctly defined for use in the PicoMite's built in program editor so you will have to use the control sequences as defined in the section Full Screen Editor of this manual..
There are no control sequences defined in that section.
Posted: 12:40pm 20 Sep 2021
  Quote  There are no control sequences defined in that section.
Thanks for the report - there should be (in all the other MMBASIC manuals) will get the following put in.
  Quote  You can also use control keys instead of the functions keys listed above. These control keystrokes are:
LEFT Ctrl-S RIGHT Ctrl-D UP Ctrl-E DOWN Ctrl-X
HOME Ctrl-U END Ctrl-K PageUp Ctrl-P PageDn Ctrl-L
DEL Ctrl-] INSERT Ctrl-N F1 Ctrl-Q F2 Ctrl-W
F3 Ctrl-R ShiftF3 Ctrl-G F4 Ctrl-T F5 Ctrl-Y
     Page 1 of 5
