Local Time 16:56 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : cmm2 v .1.  /5.07.b18 mode 9
Plasmamac
Posted: 03:09pm 16 Sep 2021
HI,
i get "Not enough heap Memory" if i try to load  a 1024x768 Png in mode 9.
The Doc say i can load every Picture if it has max the same size as the screen .
Is it me? will Cmm2 vers.2.0 handle this. Can is solve this with some tricks ?
thx
Plasma
Posted: 03:29pm 16 Sep 2021
PNG decode uses crazy amounts of memory (2x32-bit full framebuffers). Workround is to split the image in 2 and load the halves separately. G2 version should work OK
Plasmamac
Posted: 05:52pm 16 Sep 2021
Thx matherp
Plasma
