Local Time 08:25 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico Display
lew247
Posted: 04:30pm 13 Sep 2021
Has anyone seen this display?
A vibrant 1.14" IPS LCD screen for your Raspberry Pi Pico, with four useful buttons and a RGB LED!
Could it be used with MM? It looks to me like it's SPI but I could easily be mistaken
if it could be used, it would be a nice little display with 4 buttons and rgb leg as well as full colour display
Posted: 04:39pm 13 Sep 2021
It's an ST7789 so should work with the in-built driver. However, the driver expects 240x240 so you would have to avoid the missing bits of the display
lew247
Posted: 05:11pm 13 Sep 2021
Thanks Peter
mclout999
Posted: 06:04pm 13 Sep 2021
Why not try https://www.aliexpress.com/ Or Ebay you would have to wait longer but save a lot of money.  Here is just one listing based on ST7789 search.
https://www.aliexpress.com/item/4001144194129.html?spm=a2g0o.productlist.0.0.67fc7a708Uwqj7&algo_pvid=104dd30e-819f-4733-a7e7-2480a7720f40&algo_exp_id=104dd30e-819f-4733-a7e7-2480a7720f40-1&pdp_ext_f=%7B%22sku_id%22%3A%2210000014886616270%22%7D
