Local Time 08:35 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Format$ not allowed from command line?
toml_12953
Posted: 10:41am 03 Sep 2021
When I try to use format$ from the command line, I get
Format specification not found
The g, f or e is important!
I'm not used to being up this early!
Edited 2021-09-03 20:46 by toml_12953
Posted: 10:51am 03 Sep 2021
Works fine on the command line - the error says your call isn't correct
  Quote  a=10.77777
? format$(a,"**%-9.3f**")
