Local Time 08:35 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : POLYGON command is bugging me
danielkos
Posted: 09:32am 03 Sep 2021
I like the fact that I can pass the POLYGON command a whole set of polygons to render in one go. However, I have a set of polygons to be rendered where some have both an outline and a fill colour, and others only require an outline. The polygon command seems to differ from certain other drawing commands in that a fill colour of -1 does not mean "no fill specified", it's simply invalid.
This is causing me a headache right now as I've written some subroutines to load a set of 'game objects' from files (where each 'object' consists of a set of polygons to be rendered at a certain spot on screen), and populate arrays that can be passed to the POLYGON command for quick rendering of all the polygons in the 'object' at once, but there seems to be no way for me to represent 'no fill' when specifying the fill colour: I was hoping to just use -1 but the POLYGON command doesn't accept that.
I was wondering if there might be a possible workaround, like a colour value that could be treated as transparent (I'm using 8-bit colour mode), or a value that means "argument not specified", to save me having to explicitly call the appropriate form of POLYGON command for each polygon to be rendered.
Posted: 09:43am 03 Sep 2021
The polygon command works the same as all the other shape drawing commands. If a fill colour is specified you get a fill if not you get an outline (e.g. box, rbox, circle). Sorry but this is core MMbasic functionality. TEXT is a special case where -1 specifies not to draw the background colour which is the default
danielkos
Posted: 09:50am 03 Sep 2021
OK. Does this mean there's no possible way to combine filled and unfilled polygons in a single call to the POLYGON command (when running the command on a set of multiple polygons, outline and fill-colour arrays)?
