Local Time 17:23 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LOAD as an MMBASIC Command?
toml_12953
Posted: 05:05pm 22 Aug 2021
In MMBasic 05.07.01
LOAD "filename"
gives no syntax error but it doesn't load a program, either. Would it be possible to include it in a future version?
Posted: 05:21pm 22 Aug 2021
Should give a syntax error. LOAD "filename" is meaningless as it achieves nothing useful and could confuse as edit, run work from disk not memory
toml_12953
Posted: 08:08pm 22 Aug 2021
  matherp said  Should give a syntax error. LOAD "filename" is meaningless as it achieves nothing useful and could confuse as edit, run work from disk not memory
Here's what I get:
504MHz Colour Maximite 2 G2
MMBasic Version 5.07.01
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> load"fibon.bas"
Posted: 08:52pm 22 Aug 2021
On the CMM2 EDIT <filename> loads the editor into memory and points it to <filename> on the SD card for editing. There is a LOAD command, but it's not for loading program files into memory.
The reason for that is that, on the CMM2, you don't load the program into memory to edit it, you edit the ASCII file on the SD card. The memory is being used by the editor.
Edited 2021-08-23 06:56 by Mixtel90
Posted: 09:48pm 22 Aug 2021
LOAD BMP filename$
etc
Posted: 09:54pm 22 Aug 2021
Hi Jim :)
Your Clockface prog runs nicely on my Backpack after reming out the backlight control. :)
vegipete
Posted: 06:45pm 24 Aug 2021
On the CMM2, "RUN" and "EDIT" at the command prompt act on the currently active program. I've long thought it would be nice if "LOAD filename$" would set the active program.
Posted: 07:52pm 24 Aug 2021
It would just do the same as EDIT fname$, I suppose. There's nothing else it could do really as the CMM2 doesn't actually load a program in the traditional sense.
toml_12953
Posted: 05:13am 25 Aug 2021
  Mixtel90 said  It would just do the same as EDIT fname$, I suppose. There's nothing else it could do really as the CMM2 doesn't actually load a program in the traditional sense.
Not for me. EDIT "filename" opens the file for editing. I just need LOAD to make the file listable and runnable able to open if I just type EDIT after that.
>LOAD"testfile.bas"
>LIST
for i=1 to 10
print i;
next i
>run
1 2 3 4 5 6 7 8 9 10
>edit
<here the editor opens with the above program ready to edit>
Posted: 06:46am 25 Aug 2021
If you don't mind me asking, why do you need a LOAD <filename> command?
Aesthetically it might be pretty, but as Peter says, it doesn't really achieve anything useful. All it would do is to change the current filename to the new one at the cost of extra complexity to the existing LOAD command. You still have to enter a RUN, EDIT or LIST command to make anything happen, all of which can take the new filename as a parameter anyway. After using any of those the previous filename has become the current one so RUN, EDIT and LIST all work without an argument.
Posted: 06:57am 25 Aug 2021
This issue was extensively discussed by the team, including Geoff, during the early development of the CMM2 and it was agreed that LOAD "filename" was superfluous and could also cause confusion as the CMM2 does not work like the Micromite. It isn't going to change now.
All you need to do to have the same effect is type edit fname$ and then immediately press F1
There is an omission in the current firmware in that LOAD fname$ does not give an error but is just ignored. This will be fixed in a subsequent release
Edited 2021-08-25 17:08 by matherp
