Local Time 08:45 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question on field$() function
William Leue
Posted: 02:50pm 11 Aug 2021
I noticed that the field$() does not support strings where the delimiters can be multi-character strings. This is different from the way similar functions work in C and other languages.
Running this little test program:
string1$ = "A B C "
string2$ = "A  B    C "
n = 1
do
 s$ = field$(string1$, n, " ")
 print "n: ";n; " s$: ";s$
 inc n
loop until s$ = ""
print ""
n = 1
do
 s$ = field$(string2$, n, " ")
 inc n
loop until s$ = ""
end
you get:
n: 1 s$: A
n: 2 s$: B
n: 3 s$: C
n: 4 s$
n: 1 s$: A
n: 2 s$: B
n: 3 s$: B
n: 4 s$: C
n: 5 s$: C
n: 6 s$: C
n: 7 s$: C
n: 8
Of course I can write a wrapper that compresses multi-character delimiter fields to single characters. But I wonder if anyone else has encountered this and has a nice solution.
-Bill
Posted: 03:37pm 11 Aug 2021
I used Field$ to try to get delimiters of space *and* comma but it didn't work. I found the manual a little confusing on this point as it says
"...'string2' is a string holding the delimiters (more than one can be used)."
Ideally I'd have liked to get "load a, 5" but Field$ lets you have either the space or the comma, but not both. String2=" ," lets you have "load a,5" or "load a 5".
Posted: 04:10pm 11 Aug 2021
this does. VB-work-a-like Split() function .
returns the number of elements and populates a global array with them
William Leue
Posted: 05:34pm 11 Aug 2021
For what it's worth, here's a little wrapper around field$() that will work with multi-character delimiter fields. It's not very efficient.
' Wrapper for field$() to support multi-character delimiter fields
function mfield$(s$, n, d$)
 local i, j, hit
 z$ = left$(d$, 1)
 r$ = ""
 hit = 0
 for i = 1 to len(s$)
   c$ = mid$(s$, i, 1)
   for j = 1 to len(d$)
     if mid$(d$, j, 1) = c$ then
       if not hit then
         r$ = r$+c$
         hit = 1
       end if
     else
       hit = 0
     end if
   next j
   if not hit then r$ = r$ + c$
 next i
 f$ = field$(r$, n, d$)
 mfield$ = f$
end function
-Bill
Posted: 06:27pm 11 Aug 2021
Hey Bill,
Two simple optimisations:
  - Use "INC r$, c$" instead of "r$ = r$ + c$"
      - if you prefer you can use CAT insted of INC, they are synonyms.
  - Don't include variable in NEXT commands, i.e. write "NEXT" instead of "NEXT i" or "NEXT j"
jirsoft
Posted: 11:31am 12 Aug 2021
I'm using in my programs some simple function for remove duplicated of delimiter
FUNCTION removeMulti(s AS STRING, d AS STRING) AS STRING
      LOCAL INTEGER p = 1
      LOCAL STRING md = d + d
      removeMulti = s
      DO WHILE removeMulti<>"" AND p<>0
             p = INSTR(removeMulti, md)
             IF p>0 THEN
                    removeMulti = LEFT$(removeMulti, p-1) + MID$(removeMulti, p+1)
             ENDIF
      LOOP
END FUNCTION
Then you can on begin of your's first code snippet use
string2$=removeMulti("A  B   C ", " ")
and it should work...
Jiri
Posted: 11:35am 12 Aug 2021
Thanks everyone. It's something else for me to have a look at. :)
jirsoft
Posted: 11:43am 12 Aug 2021
  Mixtel90 said  I used Field$ to try to get delimiters of space *and* comma but it didn't work. I found the manual a little confusing on this point as it says
Tou can simply use "," as delimiter and then remove spaces on begin and end of every field...
FUNCTION NCtrim(s AS STRING) AS STRING
 'remove white chars from both end
 NCtrim = NClTrim(NCrTrim(s))
END FUNCTION
FUNCTION NClTrim(s AS STRING) AS STRING
 'left trim function (remove white chars from left)
 NClTrim = s
 DO WHILE NClTrim <> "" AND ASC(LEFT$(NClTrim,1)) < 33
   NClTrim = MID$(NClTrim, 2)
 LOOP
END FUNCTION
FUNCTION NCrTrim(s AS STRING) AS STRING
 'right trim function (removes white chars from right)
 NCrTrim = s
 DO WHILE NCrTrim <> "" AND ASC(RIGHT$(NCrTrim,1)) < 33
   NCrTrim = LEFT$(NCrTrim, LEN(NCrTrim) - 1)
 LOOP
END FUNCTION
Jiri
Posted: 12:05pm 12 Aug 2021
Trouble is you don't know which delimiter has been used. It could be a single space, single comma, or comma then space. Two spaces is possible, I suppose. Space then comma or two commas is unlikely. At the moment I just specify that you can use either a single comma or a single space. At least it works that way and it was easy. :) I use a single function that's called repeatedly, returning the next argument each time or a null string if there are none left. That's because the number of arguments for a command varies, sometimes varying for the same command. The delimiter at each stage can change.
I have other problems to sort out yet though. Messing about with that bit can wait. lol
jirsoft
Posted: 12:25pm 12 Aug 2021
  CaptainBoing said  this does. VB-work-a-like Split() function .
I'm using something very similar:
OPTION EXPLICIT
DIM STRING dest(1)
? split(TIME$, ":", dest())
arrPrint(dest())
? split(DATE$, "-", dest())
arrPrint(dest())
END
FUNCTION split(s AS STRING, d AS STRING, ret() AS STRING) AS INTEGER
 LOCAL STRING hlp = s+d
 LOCAL INTEGER p = 1
 split = 0
 DO WHILE hlp <> "" AND p>0
   p = INSTR(hlp, d)
   IF p>0 THEN
     INC split
     hlp = MID$(hlp, p+1)
   ENDIF
 LOOP
 ON ERROR SKIP
 ERASE dest()
 IF MM.ERRNO THEN
   split = -1 'error
 ELSE
   IF split>0 THEN
     DIM STRING dest(split)
     LOCAL INTEGER i
     hlp = s+d
     FOR i = 1 TO split
       p = INSTR(hlp, d)
       dest(i) = LEFT$(hlp, p-1)
     NEXT i
   ENDIF
 ENDIF
END FUNCTION
SUB arrPrint(a() AS STRING)
 LOCAL INTEGER i
 FOR i = 1 TO BOUND(a(), 1)
   ?"'"a(i)"'"
 NEXT i
END SUB
Jiri
jirsoft
Posted: 12:43pm 12 Aug 2021
  Mixtel90 said  Trouble is you don't know which delimiter has been used. It could be a single space, single comma, or comma then space. Two spaces is possible, I suppose. Space then comma or two commas is unlikely. At the moment I just specify that you can use either a single comma or a single space. At least it works that way and it was easy. :) I use a single function that's called repeatedly, returning the next argument each time or a null string if there are none left. That's because the number of arguments for a command varies, sometimes varying for the same command. The delimiter at each stage can change.
I would do it very simple:
OPTION EXPLICIT
DIM STRING test = "LOAD a, 5,7,q  , 6"
? "'"test"'"
? "'"justOneDelimiter(test)"'"
END
FUNCTION justOneDelimiter(s AS STRING) AS STRING
 LOCAL INTEGER p = 1
 justOneDelimiter = s
 DO WHILE justOneDelimiter<>"" AND p>0
   p = INSTR(justOneDelimiter, ",") 'replace "," with SPACE
   IF p>0 THEN
     justOneDelimiter = LEFT$(justOneDelimiter, p-1) + " " + MID$(justOneDelimiter, p+1)
   ENDIF
 LOOP
 p = 1
   p = INSTR(justOneDelimiter, "  ") 'no more than 1 SPACE
   IF p>0 THEN
     justOneDelimiter = LEFT$(justOneDelimiter, p-1) + MID$(justOneDelimiter, p+1)
   ENDIF
 LOOP
END FUNCTION
Result is
'LOAD a,  5,7,q  , 6'
'LOAD a 5 7 q 6
You can then use just SPACE as delimiter for your purpose...
Jiri
William Leue
Posted: 01:14pm 12 Aug 2021
Thanks everyone! This has been a productive discussion.
-Bill
Posted: 01:33pm 12 Aug 2021
Thanks, Jiri - I hadn't even considered that approach. :)
