Local Time 08:55 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Firmware 5.05.05: XMODEM only over serial console
Vampire05
Posted: 04:57pm 08 Aug 2021
Hi Guys,
my CMM2 has the Firmware 5.05.05 and i try to send and receive files over XMODEM protocol. Does the XMODEM SEND / RECEIVE commands only work over the USB (Serial Console) and NOT over COM1 on the 40 Pin IDE connector?
If yes, has that changed in newer firmware?
Posted: 05:56pm 08 Aug 2021
You need at least 5.6 to do this so I suggest you update to 5.7. See the latest manual for the syntax
Edited 2021-08-09 03:57 by matherp
Vampire05
Posted: 07:06pm 08 Aug 2021
Ok, thank you very much   . I will update today and retry again
Vampire05
Posted: 12:26pm 09 Aug 2021
Ok it works now over the COM1 Port. Thank you.
Is the CMM2 XMODEM SEND implementation able to work with CRC instead of Checksum?
In my case, the receiver sends an "C" instead of <NAK>. Is the CMM2 able to handle that correctly?
Posted: 11:08pm 09 Aug 2021
The Maximites are strictly the original XMODEM protocol only.
No CRC and no 1k blocks.
Vampire05
Posted: 08:59am 10 Aug 2021
Thank you very much TassyJim
Now it is clear to me why it does not work for me!
