Local Time 08:55 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Snakes and Ladders - or How to initialize arrays
Nimue
Posted: 10:58am 08 Aug 2021
Hi all
Apologies for lack of posting - been seriously ill for the last 4 months.  Back now  and 50% vaccinated to boot.
I am converting some Python code (don't hate me for mentioning the big P) that uses dictionary data types to store the positions and actions for landing on a snake or ladder in the board game.
Board_Layout = {10:33,16:37,21:41,23:2,34:15,35:54,44:76,52:31,62:43,80:99,89:68,95:74}
So you roll the dice and look up the value in the dictionary and go to that square.  For example, if you land on a 10 - this is a ladder and takes you to 33.  Quite simple.
To convert this to basic, I'm going to use an array dimensioned to be 100 long (for each square on the board. (Option Base 1) - DIM Board(100).
So in my example Board(10)=33 would simulate the dictionary.
In the cases where there is no snake or ladder, I want the array to store its index value.  For example Board(1)=1, Board(2)=2 etc.  In this case, when a player lands on 2, as there is no snake or ladder, it just returns the index.
My question is:  Can I initialize an array with the each element equal to it's index.  In C++ I can do: int list[4] = {2, 4, 6, 8};   to initialise with values.
I know...
I could write a loop to fill the array with the indexes and then define the board
I could just check for array elements that are 0, and then do nothing.
Curious if there are any clever initialising tips.
Nim
Posted: 11:13am 08 Aug 2021
MMBasic supports this:
OPTION BASE 1
DIM board(5)=(1,2,3,4,5)
which would write the values 1,2,3,4,5 into board(1),board(2) etc.
There's no way to automatically initialise with its index value AFAIK.
Nimue
Posted: 11:16am 08 Aug 2021
  Mixtel90 said  MMBasic supports this:
That's good to know.
Verbose, but I could:
DIM board(100)=(1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100)
Nice!
Thank you.
N
Posted: 11:47am 08 Aug 2021
Here is a silly way
option base 1
dim integer a(100),board(100)
sort a(),board()
erase a()
I still prefer
For i=1 to 100:board(i)=i:next
It's hardly slow... and a hell of a lot less typing.  :)
Posted: 11:49am 08 Aug 2021
That's neat, Peter. :)
I wish I understood it....   lol
Nimue
Posted: 11:50am 08 Aug 2021
  matherp said  Here is a silly way
option base 1
sort a(),board()
erase a()
Nice and elegant - I like and an interesting use case for sort and storing the index.
N
Nimue
Posted: 11:52am 08 Aug 2021
  Mixtel90 said  I still prefer
Yup - this is the way I went with at the time - just seemed like initialising with the index might have been done somewhere.
The "beauty" of this way is that my students can instinctively see what is going on.
N
With 5.07.01b4 you can also go
option base 1
dim board(100)
data 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20
data 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40
data  41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60
data 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80
data 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100
read board()
Not very useful for an index but very useful if the numbers are non-sequential
Lodovik
Posted: 02:00pm 08 Aug 2021
Very useful trick. I didn't knew that you could read an entire array at once. I've not seen this in the documentation and I've read most of it. Must have missed this somehow. I'll put this to good use, thanks.
