Local Time 09:25 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Display JPG with Picromite on HDMI
Frank N. Furter
Posted: 10:32am 12 Jul 2021
Hi!
Is there a way to display JPG images on the HDMI monitor with the Picromite? Does "load image" also work on HDMI?
Can anyone help me?
THANKS!!!
Frank
Posted: 10:54am 12 Jul 2021
Not directly but you can probably do it using the SYSTEM command
Frank N. Furter
Posted: 11:06am 12 Jul 2021
Thanks for your quick reply!
I have already tried that. I would have to switch back and forth between two images with about 0.5 Hz. I have tried fbi. Unfortunately it can only switch with a maximum of one Hz. I also need a keyboard (ESC) to exit the program. :-(
If I call only one picture at a time, it flashes only briefly and it takes much too long until the next picture comes...
Do you know of another option?
Frank
