Local Time 09:25 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Bug/unexpected behaviour wien Sub called by SetTick
Posted: 06:00pm 09 Jul 2021
Possibly this is "by design", but
> 480MHz Colour Maximite 2 G2
MMBasic Version 5.07.00
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> list "bug.bas"
Option Explicit
SetTick 1000, foo
Do : Loop
Sub foo(a%)
 Print a%
End Sub
> run "bug.bas"
Error in line 7: A is not declared
I would have expected parameter a% to have the value 0 as it would if "foo" were called without any arguments from elsewhere in the code.
This isn't a made up case, I was hoping to reuse the "foo" function with non-zero arguments elsewhere.
Posted: 06:11pm 09 Jul 2021
What an interesting test case!
Posted: 06:15pm 09 Jul 2021
Despite the thread title "... behaviour wein Sub ..." this is not a question about Vienna, I would have capitalised it if that were the case
Edited 2021-07-10 04:19 by thwill
Posted: 06:16pm 09 Jul 2021
  JohnS said  What an interesting test case!
It beat the 700 lines of actual code - not all within the SetTick/interrupt I hasten to add.
Edited 2021-07-10 04:16 by thwill
Posted: 07:33pm 09 Jul 2021
Thanks for the report.
That does not seem correct.  I cannot check it at this time as I am away for most of the month but when I get back I will look into it and report back.
In the meantime could you try it without the brackets in the definition, ie:
Sub foo a%
It should not make any difference.
Edited 2021-07-10 05:39 by Geoffg
Posted: 07:48pm 09 Jul 2021
  Geoffg said  It should not make any difference.
It didn't make a difference, the same error is reported.
Posted: 09:52pm 09 Jul 2021
A workaround so Geoff can continue his holiday in peace:
  Quote  OPTION EXPLICIT
SETTICK 1000, fooX
DO : LOOP
SUB fooX
foo
END SUB
SUB foo(a%)
PRINT a%
END SUB
vegipete
Posted: 10:39pm 09 Jul 2021
So you want an interrupt to call a subroutine that is also called by the main code.
What do you think will happen if the program flow is in this routine when the timer interrupt triggers?
Posted: 10:49pm 09 Jul 2021
  vegipete said  So you want an interrupt to call a subroutine that is also called by the main code.
I do it often.
Use SETTICK to set up the main calls and then use a direct call to run the SUB the first time instead of waiting 10 seconds (or more) for something to happen.
Posted: 11:01pm 09 Jul 2021
Thanks Jim, I was already using that workaround before you posted.
@Vegipete my understanding is that these interrupts can only happen between statements so in theory it should be possible to concoct some sort of lock to prevent the interrupt running the body of foo() if the main thread of control is already in there. I say "in theory" because I have spent my evening trying to do just that and don't think I succeeded. I will need to experiment some more on Sunday.
Edited 2021-07-10 09:02 by thwill
Posted: 01:54am 10 Jul 2021
"I do it often.
Use SETTICK to set up the main calls and then use a direct call to run the SUB the first time instead of waiting 10 seconds (or more) for something to happen."
Ditto.
To get data from sensors etc. in the setup before the main loop.
vegipete
Posted: 05:52am 10 Jul 2021
  Quote  I do it often.
Sounds to me that you have ensured that no clash will occur because you do not access the routines once the ISR is running.
Here's a silly contrived example that shows the occasional clash (at least on my 400MHz CMM2.)
> list
dim s,a(50)
settick 499, foo
do
  foo
  if s mod 50 <> 0 then print s
  pause 1
loop
sub foo
  local i
  s = 0
  for i = 1 to 50
    a(i) = a(i) + 1
    s = s + a(i)
  next i
end sub
No surprise really. Seems like some sort of 2 stage flag could solve this. Foo must not run from the ISR if it is currently running from the main routine. Instead, the ISR request needs to be held until after foo returns to the main routine.
Alas, I can't think of a suitable interlock this evening... maybe I'll dream a solution.
Posted: 06:05am 10 Jul 2021
The recommended way of using interrupts is to keep them short.
Just set a flag and let the main program loop handle the work.
That way, having the flag set by two different triggers will not cause any grief.
If the timing is slow, a long sub is OK but for rapid timing, having the main loop get the sequence right is better.
Posted: 06:48am 10 Jul 2021
I'm using the "interrupt" to flash a cursor but need to handle the main "thread" moving the cursor after it has been drawn but before it has been restored.
Posted: 08:19am 10 Jul 2021
How about just toggling a "cursor lit" flag in the ISR, Tom? Don't do anything else - you really need to handle the cursor in the main body of the program anyway. You can temporarily disable the ISR & force the cursor on or off while you do something specific then re-enable the ISR.
Posted: 08:45am 10 Jul 2021
  Mixtel90 said  How about just toggling a "cursor lit" flag in the ISR, Tom? Don't do anything else - you really need to handle the cursor in the main body of the program anyway. You can temporarily disable the ISR & force the cursor on or off while you do something specific then re-enable the ISR.
Hi Mick,
I don't see any particular reason why I can't handle rendering of the cursor in the ISR, otherwise my approach is similar to that you suggest.
For me this has now become less about the final result, there are other ways to achieve that, and more about learning how to protect against race conditions between the main "thread" and ISRs, which basically means determining what can be used atomically to implement a guard. It is also possible I have already implemented the guard correctly, but missed somewhere in my code that it needed to be checked/cleared.
Hi Mick,
Posted: 09:10am 10 Jul 2021
So good it got posted twice?  :)
Posted: 10:18am 10 Jul 2021
Generally you should not call interrupt subs from the main code.  It is OK if you are sure that the interrupt will not fire while you are doing that - like calling a SETTICK sub straight after starting the SETTICK.
If you do call an interrupt sub from the main code and the interrupt fires strange things can happen.  This includes corrupted STATICs, LOCALs, FOR loops, DO loops, etc as well as turning your hair prematurely grey.
On re reading the CMM2 manual I discovered that this warning is missing from it (it is in the Micromite manuals).  I will fix this omission on the next release.
Posted: 10:31am 10 Jul 2021
I was using a STATIC to implement a lock under the misapprehension that they were implemented as strangely scoped globals.
Geoff could you clarify what operations can be considered to be atomic and what can be interrupted by an ISR ?
