Local Time 09:25 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Notepad++ Saving Settings Solved
Chopperp
Posted: 11:47pm 07 Jul 2021
I got fed up with NP++ not showing line numbers each time I used it. The setting would not stick between uses. It also came up in a full window which was also a bit annoying.
I decided it was time to do a bit of a search & found that if NP++ is run As Administrator (right click on the *.exe file) & the settings set (particularly, display line numbers & also the opening window size) they will stick even when reopened in normal mode.
Much better now. Line numbers show in a smaller window when opened. (so far anyway)
Brian
ChopperP
Posted: 12:32am 08 Jul 2021
We must have different installations. My Notepad++ has never had problems remembering to use line numbers.
Chopperp
Posted: 01:17am 08 Jul 2021
Hi Jim
I think it might depend on where you have NP++ installed on your drive.
Some comments I read say to install it directly onto the C: drive to avoid any admin problems. Mine's in the x86 folder.
I have never had any previous problems with it before the latest upgrade.
Brian
ChopperP
