Local Time 09:25 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic: Is this the expected behaviour for FOR/NEXT
Posted: 09:03am 05 Jul 2021
Hi folks,
Not a complaint, just an enquiry, on the CMM2:
> list "loop_test.bas"
Dim num% = 5
Dim i%
For i% = 1 To num%
 Print i%
 Inc num%
Next
> run "loop_test.bas"
1
2
3
4
5
In C and other languages with which I am most familiar:
[thwill@anon]$ cat loop_test.c
#include <stdio.h>
int main() {
   int num = 5;
   for (int i = 1; i <= num; ++i) {
       printf("%d\n", i);
       num++;
   return 0;
[thwill@anon]$ gcc loop_test.c
[thwill@anon]$ ./a.out
1
2
3
4
5
6
7
8
9
10
etc.
Is the MMBasic behaviour of evaluating the FOR loop's end condition only on entry expected/intended ?
Edited 2021-07-05 19:04 by thwill
twofingers
Posted: 09:30am 05 Jul 2021
Hi Tom,
I would say it works as expected ... for an interpreter language.
Michael
PS:
I think changing the end conditions is against the for/next-loop philosophy.
Edited 2021-07-05 19:41 by twofingers
toml_12953
Posted: 09:42am 05 Jul 2021
  thwill said  Hi folks,
Dim num% = 5
Dim i%
For i% = 1 To num%
 Print i%
 Inc num%
Next
> run "loop_test.bas"
1
2
3
4
5
Yes, most BASIC implementations, both interpreted and compiled, work that way. We professional BASIC programmers (there are more of us than you may think!) are used to it and some even rely on it.
Posted: 09:48am 05 Jul 2021
  toml_12953 said  Yes, most BASIC implementations, both interpreted and compiled, work that way. We professional BASIC programmers (there are more of us than you may think!) are used to it and some even rely on it.
Thanks, I wasn't passing judgement, it just caught me out so I wanted to check it wasn't an unspecified behaviour. I'll add it to my list of BASIC idiosyncrasies alongside "non short-circuit evaluation of boolean conditions".
It's what I would expect too.
When the interpreter reads
For i% = 1 to num%
it copies num% into a termination variable. i% is a true variable so changes to that within the loop will affect how the loop runs, but changes to num% are ignored as that value is already stored.
In low level languages num% wouldn't normally be stored, just referred to, so you'd get a continuous increment in C or assembler.
toml_12953
Posted: 10:00am 05 Jul 2021
That behavior of ignoring changes to the terminating variable in a FOR-NEXT loop is actually in the ANSI/ISO standard for BASIC so it's well established. I wouldn't call it an idiosyncrasy, exactly. FORTRAN (which played a big part in BASIC's development) seems to work that way as well.
"non short-circuit evaluation of boolean conditions" is NOT a usual feature of BASIC. In standard BASIC, this will NOT give an error:
DIM a(3)
IF a(2)>0 AND a(5)=0 THEN
  PRINT"OK"
END IF
END
Edited 2021-07-05 20:02 by toml_12953
Posted: 10:12am 05 Jul 2021
  toml_12953 said  That behavior of ignoring changes to the terminating variable in a FOR-NEXT loop is actually in the ANSI/ISO standard for BASIC so it's well established. I wouldn't call it an idiosyncrasy, exactly. FORTRAN (which played a big part in BASIC's development) seems to work that way as well.
Not judging, but convenient since I am contemplating a transpiler from Ratfor.
  Quote  "non short-circuit evaluation of boolean conditions" is NOT a usual feature of BASIC. In standard BASIC, this will NOT give an error:
DIM a(3)
  PRINT"OK"
END IF
END
OK, I think we may have been down this rabbit hole before
It is my understanding that MMBasic does not short-circuit evaluate, and nor I think does Visual Basic (hence the existence of AndAlso for short-circuit evaluation). Is non short-circuit evaluation standard for Microsoft BASICs ?
toml_12953
Posted: 10:18am 05 Jul 2021
DIM a(3)
  PRINT"OK"
END IF
END
True. MS BASICs don't follow the de jure standard which requires BASIC to short circuit boolean evaluation. They follow the de facto standard.
Edited 2021-07-05 20:18 by toml_12953
Posted: 01:17pm 05 Jul 2021
  toml_12953 said  True. MS BASICs don't follow the de jure standard which requires BASIC to short circuit boolean evaluation. They follow the de facto standard.
Thanks for the confirmation ... again it it convenient because that is apparently the behaviour of most FORTRANs (excluding GNU) and thus of Ratfor, I was afraid I might have to some contortions in the transpiler.
