Local Time 09:46 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New Version: Micromite MMBasic Ver 5.05.04
Posted: 01:14am 15 Jun 2021
I have a new version of MMBasic for the Micromite, Micromite Plus and the Windows/DOS version.  It is Ver 5.05.04 and you can download it from here: http://geoffg.net/micromite.html   (scroll to the bottom of the page)
This is a minor update that fixes some trivial but annoying bugs.  Normally I wait for a serious issue to be fixed before releasing a new version but it has been almost a year since the last release and I thought it worth releasing this version to completely clear the bug list.  Thankfully serious bugs are becoming increasingly rare.
This version adds one new feature which will be appreciated by users who need to run the Micromite off a battery.  Now the Micromite can run at a clock speed as low as 0.5MHz which reduces the power consumption to 1mA.  This has a number of limitations so check the Manual and/or Change Log for the details.
Posted: 02:04am 15 Jun 2021
Thanks Geoff, and all the other contributors, MMbasic is outstanding.
Phil
Chopperp
Posted: 03:01am 15 Jun 2021
Having trouble unpacking files on 2 W10 computers. Mainly with the PDF's but also the HEX files.
Unexpected error.
ChopperP
KeepIS
Posted: 03:06am 15 Jun 2021
FYI No errors on my W10 PC
Posted: 03:33am 15 Jun 2021
Having trouble here also.
I tried with Firefox and Edge and extracting with winrar and explorer.
No joy with any combination.
KeepIS
Posted: 03:52am 15 Jun 2021
I just downloaded again and this time used the Windows file manager (normally don't use that) and clicked on the ZIP, everything is there and can be copied straight out as normal, Window 10-PRO 64, every current update including the one that adds the Stupid Weather and News feed icon on the task bar (removed).
Strange?
Posted: 03:56am 15 Jun 2021
Same issue with W10 inbuilt zip tool. 7Zip also fails to extract same files, it appears to work but the files are zero bytes.
KeepIS
Posted: 04:12am 15 Jun 2021
FYI I've checked the unzipped pdf manuals, Hex and readme files, all are perfect.
Posted: 04:29am 15 Jun 2021
good work geoff     i hope you have been keeping well!
unfortunately am having the same problems as others with the archive being corrupt. using linux here, have tried clearing the browser cache.
btw, do you maintain a list of past 'suggested additions'? i've made a few over the years - some have happened, others have not. it would be good to know (a) what once have been considered, (b) what ones have been included, and (c) what ones have been rejected. just to avoid making the same suggestions repeatedly.
the last one i remember making, a year or so back, was for pulsein to be extended to collect a sequence of pulse lengths into an array for decoding wireless remote control signals.
rob   :-)
Posted: 04:45am 15 Jun 2021
@robert.rozee "the last one i remember making, a year or so back, was for pulsein to be extended to collect a sequence of pulse lengths into an array for decoding wireless remote control signals."
That would also be useful for decoding the DHT11 temp & humidity sensor. There may be other devices that use variations of PWM encoding that could use it.
MM50504 won't extract in Win XP either, so I don't think it's W10 problem.
Phil
led-bloon
Posted: 04:50am 15 Jun 2021
DOS & Lite version zip - ok
Full version zip - No good!
Raspberry Pi
led
Miss you George
Posted: 06:07am 15 Jun 2021
(Using Linux)
Full version reported bad after Documentation/Micromite Manual.pdf
Lite & "DOS" are OK
Posted: 07:24am 15 Jun 2021
Thanks Geoff.  :)
Full version downloaded using the Vivaldi browser in Win10 no problem. Contents of zip appear to be ok.
athlon1900
Posted: 07:25am 15 Jun 2021
Same issue here   , Win7 Ultimate and WinRAR 5.70 .
athlon1900
twofingers
Posted: 08:01am 15 Jun 2021
No issues here (Win7 Ultimate, Winrar 3.9)
Michael
PS: Many thanks Geoff!
Posted: 08:20am 15 Jun 2021
W10 download (edge), extract -> errors
Copy downloaded file to linux PC, Gnome Archive Manager -> error
Extracted files : both hex files have size 0, docs in folders seem OK.
@twofingers: did you check filesizes OK ?
KeepIS
Posted: 08:26am 15 Jun 2021
I'm using 7-Zip 19.00(64) on WIN-10
Everything is perfect including all files and file sizes.
Chopperp
Posted: 08:34am 15 Jun 2021
Just tried 7-Zip. Gave 0 byte files.
ChopperP
KeepIS
Posted: 08:39am 15 Jun 2021
What version? I can read every PDF and read Every Hex file.
KeepIS
Posted: 08:47am 15 Jun 2021
Well, this is interesting, I just downloaded the ZIP (full version) again, file sizes are all ok BUT some of the PDF and Hex files are now throwing an error WT?
Error: Invalid size or checksum or unsupported compression format.
File sizes are ok in the ZIP but extract to 0 bytes because the extraction never really completes with 7-Zip file manager.
Strange that 2 pdf files are fine and 3 others aren't (Header Error)
Edited 2021-06-15 18:59 by KeepIS
