Local Time 19:01 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Line continuation character, SWAP
bar1010
Posted: 07:14pm 07 Jun 2021
FreeBASIC uses the underscore character for line continuation.
Do we have something similar to use in the editor?
If not, could we have this functionality added?
Also I have seen a SWAP command in QuickBASIC which swaps the values of two variables.
Could we have this functionality added?
Posted: 07:30pm 07 Jun 2021
I will save Peter some time:
Line continuation: see http://www.thebackshed.com/Forum/ViewTopic.php?TID=12819
SWAP: probably not as the 128 tokens available for MMBasic commands has been reached on the CMM2 - it's an architectural limitation.
Edited 2021-06-08 05:31 by thwill
Posted: 07:34pm 07 Jun 2021
Note that because parameters are pass by reference you could write SUBroutines to provide your own SWAP, you'd need one per type and unfortunately you'd have to pay a significant performance penalty over an inbuilt command.
twofingers
Posted: 07:36pm 07 Jun 2021
  thwill said  SWAP: probably not as the 128 tokens available for MMBasic commands has been reached on the CMM2 - it's an architectural limitation.
I think, that is correct.
But it's easy to make your own:
For example, you might define a subroutine to swap two values, as follows:
SUB Swap a, b
LOCAL t
t = a
a = b
b = t
END SUB
(CMM2 manual p27)
... or write a short CSUB
Michael
The lone and ...
Posted: 08:23pm 07 Jun 2021
it is likely you will only ever use SWAP in one or two places in any given program.
The overhead of a SUB makes for a very slow SWAP. If you are doing it in tight loops (e.g. in a sort function), better to do it inline for big increase in speed.
All things speed-wise are relative of course
LeoNicolas
Posted: 10:59pm 07 Jun 2021
There is a nice old challenge with the swap function. How can we do it without creating a third variable?
Edited 2021-06-08 09:19 by LeoNicolas
Posted: 06:06am 08 Jun 2021
Does it work with floating point, not to mention strings...
LOL
Posted: 06:40am 08 Jun 2021
Now there's a thought ...
Swap the variable pointers, not the variables.
Edited 2021-06-08 16:40 by Mixtel90
