Local Time 09:57 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : The "Electronics" forum
Posted: 11:07pm 04 Jun 2021
Hi folks,
Is there much crossover between this forum and the "Electronics" one? I don't seem to see the same names and I find my posts there less likely to get commented on. TBH at least 50% of the conversation seems to be about inverters so it looks like it might not have a generic "electronics" focus?
Anyway this is all just a conversational way of saying I posted a question about what glue I should consider for mechanically attaching SMD components to PCBs when there are no solder pads and if anyone could see there way to answering it I would appreciate it
Posted: 01:24am 05 Jun 2021
Hot melt glue can be used provided wires are soldered on first. Hold the device in a wooden clothes peg with one terminal sticking out a little then solder on some thin enameled wire. Repeat for the other pins. Stick it in place with a dot of glue.
5 min. epoxy also works but repositioning is difficult.
Posted: 06:15am 05 Jun 2021
Thanks Phil, I'm not sure my fine needlework is up to that without the component stuck down first but I will give it a go
Edited 2021-06-05 16:16 by thwill
Posted: 06:39am 05 Jun 2021
Tom,
I replied in the electronics group.
Posted: 06:41am 05 Jun 2021
  bigmik said  Tom,
I saw, thanks Mick, I just haven't got around to replying yet.
