Local Time 19:00 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : line input command unexpected behaviour
crez
Posted: 08:49pm 04 Jun 2021
Open "doc.txt" For input As #1
Line Input #1,t$
For i= 1 To 10
Print Asc(Mid$(t,i,1)),
Next i
Close #1
t=Input$(10,#1)
For i= 1 To 10
Next i
Close #1
End
gives
> RUN
97      32      98      32      99      32      100     32      101     32
97       9       98       9       99       9      100      9       101      9
line input returns spaces = chr$(32)
input$ returns tabs = chr$(9) which is what is in doc.txt
Why?
Posted: 03:24am 05 Jun 2021
LINE INPUT uses the same mechanism for getting a line as does the console and loading a program from an SD card.  This includes turning tabs into spaces, setting bit 8 to zero, removing control chars and handling the variations in terminating the line (ie, CR, LF, CR/LF, etc).
This was implemented many years ago and, from memory, it matches the way traditional BASICs worked (primarily Microsoft BASIC).  As you pointed out INPUT$() is the way to go if you want every byte without translation.
crez
Posted: 03:41am 05 Jun 2021
Thanks Geoff,
   I was tidying up a bit of code I wrote a while back that reads tab delimited fields. I couldn't remember why I hadn't used 'line input', but I do now.
David
Posted: 04:12am 05 Jun 2021
Same effect in a different setting - send an email containing a table with neat columns of data and it arrives messed up. Tabs turn into to spaces.
Posted: 06:13am 05 Jun 2021
  Geoffg said  ... handling the variations in terminating the line (ie, CR, LF, CR/LF, etc).
Are you sure it handles CR without LF, i.e. Classic Mac style? I'm sure Turbo64 and I encountered one of those abominations recently and I had to write my own Line Input replacement. This was on the CMM2.
Posted: 08:49am 05 Jun 2021
When using INPUT or LINE INPUT MMBasic for the Micromite will work correctly with lines terminated by a CR/LF pair or a single LF.  This will not affect files written by MMBasic (which normally use CR/LF) but files written with strange combinations such as a single CR or LF/CR should use INPUT$() instead.  The console input will translate CR into a newline so pressing Enter on a keyboard will not cause problems.
I'm not sure if this has carried into the CMM2 but I would guess that it has as it is in the core of MMBasic.
I had a lot of trouble with detecting end of line (damn DOS and the rest of the world, why could you not be like UNIX?).  After a lot of attempts the above was the best that I could come up with.
