Forum Index : Microcontroller and PC projects : Cash Gift for sample EEPROM SPI / I2C Micromite code
| pdeivendran Newbie Joined: 18/09/2020 Location: MalaysiaPosts: 9 |
Dear Guys, I am at my wits-end, trying to solve the above EEPROM communication using the Micromite. I have tried almost everything I could to solve it but only ending in frustration. Maybe there is something I am NOT doing right. The chips in question are the 25AA02UID (SPI) and the AT24CS01 (I2C) from Microchip. What I am attempting is to: 1. Read the chip UID Serial Number 2. Write data to the unprotected memory array 3. Read data from memory array Having said the above, as my last attempt before dumping this entire effort, if I am not being too rude or insulting, I would like to offer you a USD 150 cash gift for your troubles, for a set of proven sample codes for both the above chipsets. If you are agreeable to this and have a PayPal account, I will transfer this amount to you before your posting. My email id. is pdeivendran@me.com Thanking you in advance Dave |
| flasherror Senior Member Joined: 07/01/2019 Location: United StatesPosts: 159 |
Don't have any of those chips but if you are having problems with both SPI and I2C chips then it is likely not an interface related issue. Which micromite you are using/firmware version? What are you trying and what is not working? |
| CaptainBoing Guru Joined: 07/09/2016 Location: United KingdomPosts: 2171 |
this might give you some pointers http://www.thebackshed.com/Forum/ViewTopic.php?TID=6917 Edited 2021-06-03 02:36 by CaptainBoing |
| vegipete Guru Joined: 29/01/2013 Location: CanadaPosts: 1193 |
My stuff pile includes a 25AA512 I/P SPI EEPROM. (I also have a single FT24C256A, although I haven't tried anything with it.) The following quick test program seems to work with my SPI EEPROM. Note that addressing and instruction set are a little bit different between the SPI EEPROM I have and the one you indicated. Mine has 16 bit addresses, and some flash erase instructions. However, the demo program should kind of still work if you change 2 places to only write the (low) address byte. I say 'kind of' because you have to obey page rules when writing - max 16 bytes at a time, within a single page. From the data sheet: Also, my chip has a 'Read Electronic Signature' command whereas yours has a unique serial number stored at address &hFC to &hFF. Hopefully this helps a bit. Print "EEPROM Test" Const SPI_CS = 2 Pin(SPI_CS) = 1 'deselect SPI EEPROM SetPin SPI_CS, dout SPI open 100000,0,8 Print "Read electronic signature:"; Pin(SPI_CS) = 0 dummy = SPI(&b10101011) dummy = SPI(0) dummy = SPI(0) result = SPI(0) Pin(SPI_CS) = 1 Print result Print "EEPROM Satus:";SPI_EE_Read_Status() Print "old EEPROM contents:" Print SPI_EE_Read_String(0,45) ' read 45 bytes starting from address 0 ' write some stuff to EEPROM SPI_EE_Write_String 10, "This is a test!" SPI_EE_Write_String 30, Time$ + " " ' spaces to blank out previous data SPI_EE_Write_String 40, Date$ Print "new EEPROM contents:" Print SPI_EE_Read_String(0,45) ' read 45 bytes starting from address 0 SPI close End Sub SPI_EE_Enable_Write Pin(SPI_CS) = 0 dummy = SPI(&b00000110) ' enable writes Pin(SPI_CS) = 1 End Sub Sub SPI_EE_Disable_Write Pin(SPI_CS) = 0 dummy = SPI(&b00000100) ' disable writes Pin(SPI_CS) = 1 End Sub ' Write a string to EEPROM ' WARNING - dumb code doesn't know about page boundaries! Sub SPI_EE_Write_String addr,d$ Local integer dummy If Len(d$) > 0 Then SPI_EE_Enable_Write Pin(SPI_CS) = 0 dummy = SPI(&b00000010) ' write instruction dummy = SPI(addr \ 256) ' high byte of address dummy = SPI(addr Mod 256) ' low byte of address SPI write Len(d$), d$ Pause 1 Pin(SPI_CS) = 1 Pause 500 ' wait for write to finish - should check STATUS instead SPI_EE_Disable_Write EndIf End Sub ' Read n bytes from EEPROM, return as a string Function SPI_EE_Read_String(addr,n) As string Local integer i,dummy,v Local d$ = "" Pin(SPI_CS) = 0 dummy = SPI(&b00000011) ' read instruction dummy = SPI(addr \ 256) ' high byte of address dummy = SPI(addr Mod 256) ' low byte of address For i = 1 To n ' loop through and read each byte v = SPI(0) ' dummy output to get input If v < 32 Then v = 32 ' WARNING - turn unprintable into space If v > 127 Then v = 32 ' WARNING - turn unprintable into space d$ = d$ + Chr$(v) Next i SPI_EE_Read_String = d$ Pin(SPI_CS) = 1 End Function ' read the status register Function SPI_EE_Read_Status() Pin(SPI_CS) = 0 dummy = SPI(&b00000101) Read_SPI_EE_Status = SPI(0) Pin(SPI_CS) = 1 End Function Visit Vegipete's *Mite Library for cool programs. |
