Local Time 09:57 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Expansion Card - Prototyping Card
siwypiotr
Posted: 05:39pm 30 May 2021
This is simple prototyping card with various signals exposed.
Can be purchased here:
https://sklep.pslabs.pl/Prototyping-Card-Expansion-System-p170
Full Kicad project can downloaded here:
https://github.com/pslabs-ps/CMM2-ExpansionCard-ProtoSimple/blob/main/Kicad/proto_vard_simple
All files included, this will help You to create new cards
Instruction, code can be found on Github:
mclout999
Posted: 11:00pm 30 May 2021
Hi.  Is this the system that that card I won is needed for, Well not this card but the system it plugs into?
siwypiotr
Posted: 08:15am 31 May 2021
  mclout999 said  Hi.  Is this the system that that card I won is needed for, Well not this card but the system it plugs into?
Hi
Yes, I remember about You. You have won relay card, this is still a prototype, I think that in 3 weeks it will be ready. I will inform You.
You have won the card not the expansion system. Expansion is described here:
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=13843
