Local Time 09:57 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Expansion System
siwypiotr
Posted: 04:33pm 30 May 2021
Dear Maximite Fans!
I would like to present You new product, Maximite Expansion System.
Expansion system for CMM2 was created to add easy to use expansion system for CMM2, expansions can be daisy chained, release Your creativity and try to find where is the limit!
In next 2 days I will also release various expansion cards
Schematic can be found here: schematic REV A v02
Instruction, code can be found on Github: CMM2 Expansion System
Can be purchased here: CMM2 Expansion System
1. 2x20 IDC connector compatible with Maximite
2. 2x13 IDC additional connection for expansion system
3. Power supply selector and power supply daisy chain jumper
4. Power supply selector and power supply daisy chain jumper
5. Edge connector slots
6. 12V DC 2,5/5,5mm connector
7. Place for filtering capacitators (not included)
Posted: 05:58pm 30 May 2021
Er, wrong URL for purchase I think.
siwypiotr
Posted: 06:11pm 30 May 2021
  JohnS said  Er, wrong URL for purchase I think.
Yes You are right, somehow there is no Edit button so I can not correct this. Here is correct link:
https://sklep.pslabs.pl/Maximite-Expansion-System-p169
romba6
Posted: 06:24pm 30 May 2021
Are you still NOT shipping to the UK ?
Edited 2021-05-31 04:25 by romba6
siwypiotr
Posted: 06:29pm 30 May 2021
Unfortunately UK is the only country in whole world Im unable to deliver.
Posted: 06:43pm 30 May 2021
  siwypiotr said
  romba6 said  Are you still NOT shipping to the UK ?
On the plus side https://youtu.be/4-tFsTN6lWY
Edited 2021-05-31 04:45 by thwill
Posted: 06:58pm 30 May 2021
Looks really cool Piotr and thanks for publishing the designs so that those of us in England-land (not a typo) can build our own using components sourced from Communist dictatorships.
siwypiotr
Posted: 08:37pm 30 May 2021
  thwill said  Looks really cool Piotr and thanks for publishing the designs so that those of us in England-land (not a typo) can build our own using components sourced from Communist dictatorships.
If You will be lucky to source the parts, it looks like there are shortages whatever I want to buy in PRC :)
