Local Time 10:07 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Generic MMBasic bug with STATIC
Posted: 11:54am 28 May 2021
Spun off from here: https://www.thebackshed.com/forum/ViewTopic.php?TID=13459&PID=169564
Present on CMM2 and (according to @matherp) latest development version of the MM2 firmware:
> list "static-bug.bas"
Option Explicit On
Option Default None
Option Base 0
If foo%(10)         = 11 Then Print "1: PASS" Else Print "1: FAIL"
If bar_1%(11)       = 11 Then Print "2: PASS" Else Print "2: FAIL"
If bar_1%(0)        = 11 Then Print "3: PASS" Else Print "3: FAIL"
If bar_2%(foo%(10)) = 11 Then Print "4: PASS" Else Print "4: FAIL"
If bar_2%(0)        = 11 Then Print "5: PASS" Else Print "5: FAIL"
Function foo%(a%)
  foo% = a% + 1
End Function
Function bar_1%(b%)
  Static static_1% = -1
  If static_1% = -1 Then static_1% = b%
  bar_1% = static_1%
End Function
Function bar_2%(c%)
  Static static_2% = -1
  If static_2% = -1 Then static_2% = c%
  bar_2% = static_2%
End Function
> run
1: PASS
2: PASS
3: PASS
4: PASS
5: FAIL
The problem appears to be something to do with the initialisation of a STATIC variable from a function parameter that is itself the "temporary" result of another function call.
Edited 2021-05-28 21:55 by thwill
Posted: 01:41pm 28 May 2021
Good grief.  That does not look easy.
Thanks for the report and demo code.  I will have a crack at it for the next version.
Posted: 01:56pm 28 May 2021
Thanks Geoff, I promise I came across it guilelessly from a genuine use-case and was not sequestered in my shed trying to come up with brain-twisters for Peter
Posted: 06:26am 29 May 2021
  thwill said  I came across it guilelessly from a genuine use-case and was not sequestered in my shed trying to come up with brain-twisters
That's great.  Either way, bit by bit, bug by bug, these pesky "features" are being found and eliminated.
BTW thank you very much for the demo code.  I have found that a short demonstration of a bug (like this) can save a huge amount of time isolating it.
