Local Time 10:07 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Update for "Sunset" Puzzle
William Leue
Posted: 04:19pm 26 May 2021
Attached is the ZIP file for version 1.1.0 of the Sunset Puzzle.
I added an automated solution option because finding a solution manually is very hard and tedious, and also because it was fun :-).
The automated solution is queued by pressing the '@' key. There is a screen that allows you to choose how much of the solution to see, based on the number of times the 'sun' piece moves 1 to 6, where 6 is the final solution. You can also choose to see the solution animate at 1, 2, 4, or 8 moves per second.
Note: I had accidentally named the original posting "Sundown.zip".
Enjoy!
-Bill
Sunset.zip
