Local Time 10:13 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Peeking a scalar variable, what's going on here?
Posted: 04:10pm 15 May 2021
Hi folks,
I suspect I'm being an idiot, but why is this not working:
> list "foo.bas"
Option Base 0
Option Explicit On
Option Default None
Dim a%(1)
a%(0) = &hAABBCCDD
Print Hex$(Peek(Var a%(), 0))
Dim a_addr% = Peek(VarAddr a%())
Print Hex$(a_addr%)
Print Hex$(Peek(Byte a_addr%))
Print
Dim b%
b% = &hAABBCCDD
Print Hex$(Peek(Var b%, 0))
Dim b_addr% = Peek(VarAddr b%)
Print Hex$(b_addr%)
Print Hex$(Peek(Byte b_addr%))
> run "foo.bas"
DD
3003FF00
DD
DD
3800E178
Error in line 19: Address
a_addr% is obviously the address of the storage for the first element of a%(), but what is b_addr% and why can't it be PEEKed ?
Edited 2021-05-16 02:10 by thwill
jirsoft
Posted: 04:42pm 15 May 2021
Hi Tom,
it's working for me. Instead of your error, I got DD...
Jiri
Posted: 04:53pm 15 May 2021
  jirsoft said  Hi Tom,
That's what I had expected.
What firmware version are you running?
Posted: 06:37pm 15 May 2021
Fixed in b33 just posted
  matherp said  Fixed in b33 just posted
Thank you.
