Local Time 19:42 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for DOS download missing
karjo238
Posted: 04:39am 10 May 2021
I may just be getting on a bit and losing the plot, but I can't seem to download the DOS version of MMBasic from Geoffs website.
Has it been relocated / gone missing, or have I just been looking in the wrong place
Joseph.
Posted: 05:18am 10 May 2021
Works for me....
LINK
karjo238
Posted: 05:31am 10 May 2021
Strange. It just doesn't want to download on my new laptop... My phone downloaded it no problem, but not the laptop.
More investigation needed, I think...
Thanks for the response anyways
Posted: 05:35am 10 May 2021
I have attached it to this thread as a ZIP - see if you can download it from this thread.
DOS_MMBasic.zip
karjo238
Posted: 05:43am 10 May 2021
Alright, this bugged me a bit, so after a bit of faffing around I discovered it's the new version of Microsoft Edge that is causing the problem. After I switched to Firefox, all was well.
I haven't used Edge in years and it seems by default it doesn't let you do certain things, which you don't find out about until you're blocked from doing it
All sorted though. I have a copy, and I'll start plugging away at some ideas I have clattering about in my head.
Many thanks for all the help
toml_12953
Posted: 07:07am 10 May 2021
  karjo238 said  Alright, this bugged me a bit, so after a bit of faffing around I discovered it's the new version of Microsoft Edge that is causing the problem. After I switched to Firefox, all was well.
I'm using Windows 10 Edge Version 90.0.818.56 to download it with no problem. What version do you have?
Posted: 08:13am 10 May 2021
Oh, the joys of browsers...
For some reason I can no longer download stuff from Geoff's web site using Pale Moon (a fork of Firefox). Vivaldi is fine though. I don't remember using Edge on it.
Posted: 08:19am 10 May 2021
Yeah, that sounds like Edge.
Microsoft know what is best for you - even when they don't.
Posted: 01:27pm 10 May 2021
I think that this issue was caused by me switching the website to https: from the original http:  I did this because Google was complaining about my use of http:
The problems seem to only occur with downloads and with some browsers.  I need to do some work to figure out how to leave downloads as http: while the rest of the website is https:
The joys of hosting a website
Edited 2021-05-10 23:29 by Geoffg
Bowden_P
Posted: 02:35pm 10 May 2021
Hi all,
Interesting comments. I can't download from Geoffg's site now either - I end up with an empty folder. I am using XP Pro SP3 with Firefox. ( An older non-supported version now.)
When MMBasic v5.05.03 came out I asked Phil Boyce (Mr. Micromite.org) for help. He emailed the folder to me.
With regards, Paul.
Nothing so constant as change.
Posted: 03:17pm 10 May 2021
I sometimes find that Chrome will download in Incognito mode when it won't in Normal mode.
karjo238
Posted: 07:58pm 10 May 2021
  Geoffg said  I think that this issue was caused by me switching the website to https: from the original http:  I did this because Google was complaining about my use of http:
I just quickly wanted to say that because I have a new laptop, the default security settings for Windows and Edge may well be interfering with things like this. I'm at work currently, so when I've finished I'm going to sit down and have a good look at this.
More to come
KeepIS
Posted: 01:56am 11 May 2021
FYI I've used MS Edge since it came out in an upgraded configurable format, running the latest version of Edge and Geoffs site works perfectly, everything downloads correctly, including MMBasic for DOS.
Mike.
Edited 2021-05-11 11:56 by KeepIS
NANO:Inverter V 8.4ksLinux AvrDude GUI script V4.1
karjo238
Posted: 04:29am 11 May 2021
Alright, two steps forward and one backward it seems. I was wondering if some setting in Windows was stopping me from downloading Zip files, so I went out and tested downloading a ZIP and a EXE file from various websites.
Both worked flawlessly. This got me scratching my head a bit, so I went to Geoffs site and tried to download a different ZIP file (which was also addressed using HTTPs), which worked fine. As far as I can tell, it was only that one file which seems to be giving me grief.
Anyhow, thanks to Grogster I was able to download the file off of this comment thread, so all is well.
I thought Windows or Edge security might have been at fault here, but no. It just seems to fall over on this one file. Just to aggravate things, Firefox downloaded it without a hitch.
I seemed to have picked a day to find a problem that most likely has a really obscure solution, or in the words of the immortal Lloyd Bridges - "Looks I picked the wrong week to quit amphetamines"
Many thanks for the suggestions and feedback here. One day when I have some time and patience spare I will sit down and pick through this problem and see what happens when I get to the other side of the rabbit hole...
..."we're all mad here. I'm mad. You're mad."
"How do you know I'm mad?" said Alice.
"You must be," said the Cat, "or you wouldn't have come here."
Rado
Posted: 01:58pm 11 May 2021
Oddly, I've just tested it and had no issue using Edge to access https://geoffg.net/WindowsMMBasic.html and download and run the file. Only Windows Defender complained about an unknown application, but that is not the issue here.
https://www.mmbasic.com/Download/DOS_MMBasic.zip gives me 404, as it seems that there's no file on the server.
karjo238
Posted: 12:03am 12 May 2021
  Rado said  Oddly, I've just tested it and had no issue using Edge to access https://geoffg.net/WindowsMMBasic.html and download and run the file. Only Windows Defender complained about an unknown application, but that is not the issue here.
That's one of the messages I get. I also get Error 418, but as far as I can tell, that is related to an April Fool's joke, so it's really puzzling me right now
Posted: 12:31am 12 May 2021
Another data point.
Downloaded fine with Opera on W10 from the link on Geoff's site.
Posted: 06:50am 12 May 2021
  Rado said  https://www.mmbasic.com/Download/DOS_MMBasic.zip gives me 404, as it seems that there's no file on the server.
Yes. It's at https://geoffg.net/Downloads/WindowsMMBasic/DOS_MMBasic.zip
(different web site!)
It's also at http://geoffg.net/Downloads/WindowsMMBasic/DOS_MMBasic.zip
(Downloaded fine for me at both.)
