Forum Index : Microcontroller and PC projects : Armmite F4 - 40-pin display addapter
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9137 |
I've taken the liberty of re-drawing Peter's Armmite F4 to 40-pin TFT display adapter circuit. This version shows the pin views of both boards, with the pins rearranged to suit the physical arrangement. It may be of some use to those who wish to mount the F4 behind a display but retain access to all the F4 connections. PM_F4-40pin.pdf Mick Zilog Inside! nascom.info for Nascom & Gemini |
