Local Time 10:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pic with 512k flash in 28-pin DIP
Posted: 09:03am 01 May 2021
happened upon these today:
dsPIC33EP512MC202
dsPIC33EP512MC502
dsPIC33EP512GP502
https://ww1.microchip.com/downloads/en/DeviceDoc/dsPIC33EPXXXGP50X-dsPIC33EPXXXMC20X-50X-and-PIC24EPXXXGP-MC20X-Family-Data-Sheet-DS70000657J.pdf
they are 16-bit PIC33 devices in a 28-pin SDIP package (same as the MX170), with 512k of flash but only 48k of RAM. 70MHz max CPU clock.
interesting?
rob   :-)
Edited 2021-05-01 19:04 by robert.rozee
Posted: 12:13pm 01 May 2021
I've come across the 28-pin dsPIC series before, indeed I used one to experiment with a little one-chip oscillosope project that someone had done. They are designed for digital signal processing rather than general control systems. I can't remember which version I got now, it was quite a while ago. I didn't experiment with them as at the time I was using the GCBASIC compiler which doesn't support them and there are still two of them (I think) sitting in a tin in the shed.
