Local Time 19:55 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Connector Identification
lew247
Posted: 06:27am 26 Apr 2021
Does anyone know the name of this connector?
so I can buy the correct matching plug
it's 2.54mm (0.1")pin spacing
Edit:
It looks similar to a JST XH connector but these are 2.5mm and the connector is definitely 2.54mm
Edited 2021-04-26 21:21 by lew247
Mindwarp
Posted: 01:45am 27 Apr 2021
Looks like JST-XH https://www.amazon.ca/Litorange-Housing-Adapter-Connector-Terminal/dp/B087CPV5T4/ref=sr_1_7?dchild=1&keywords=JST-XH&qid=1619487821&sr=8-7
Edited 2021-04-27 11:47 by Mindwarp
Posted: 04:49am 27 Apr 2021
Chances are that 2.5 is 2.54 rounded down. Even if 2.5 is genuine, with just 4 pins it will flex to fit. If it were 40 pins you would have a problem.
Mindwarp
Posted: 07:57pm 27 Apr 2021
I searched for 2.54 mm specifically and mostly get results for the 2.5 mm Xh connector. The ones that do list as 2.54 mm are mostly from Chinese sites, maybe a discrepancy in the conversion of 0.098 inch to mm. Oddly enough, 0.098 inch is actually 2.4892 mm so the variation seems to swing in both directions.
Edited 2021-04-28 06:00 by Mindwarp
