Forum Index : Microcontroller and PC projects : Windows Console CFunction Generator
| GerryL Regular Member Joined: 24/01/2019 Location: AustraliaPosts: 46 |
Not sure if this is useful to others who play around with CFunctions, but attached is a Win32 console application with instructions for converting ELF files into CSub/CFunctions. It will handle ELF files generated for the MMPlus (PIC32MX470) and CMM2 (STM32H743IIT6). I have included the source code files in case you want to customise it for your own use, but be aware I'm no expert programmer and I apologies to those who don't like the C++ Standard Template Library. It's been tested on my CMM2 and E100 and it seems to work fine with my C functions. I just find it convenient to drag and drop an ELF file onto the application icon on my desk top to generate a CSub and found it really useful in developing my Astro CSub (solar system stuff) for the CMM2, it's just under 100k in size, and this will turn the ELF to a CSub in under a second and leave a copy on the clipboard, so making it easy to work through all my endless self-inflicted bugs. CFunc Gen.zip Gerry |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3881 |
It does look useful, thanks. CMM2 CFunctions are on my todo list (but not near the top). I'll be glad to have this tool when I start. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
