Local Time 10:37 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite F4 - "Out of Memory": What would you expect from MEMORY cmd
Andrew_G
Posted: 02:19am 11 Apr 2021
Sorry to be such a PITA but . . .
I'm running MMBasic 5.07.00b9 on my F4. I'm porting a program that runs on a MM170 to my ArmmiteF4.
I keep getting an "Out of Memory" error on the F4.
So I checked with a MEMORY command both within the program and in Console mode.
Here is what I get with no program loaded (in fact it is just after I re-flashed it).
memory
Flash:
  0K ( 0%) Program (0 lines)
132K (100%) Free
RAM:
  0K ( 0%) 0 Variables
  0K ( 0%) General
114K (100%) Free
Wouldn't you expect more than 114k RAM free (the example in the manual shows 5470k).
(And I've tried Key 1 at power-up and two different F4 boards.)
Thanks,
Andrew
Posted: 03:10am 11 Apr 2021
Manual is retaining the number for the CMM2--5470K. 114K is correct for the F4. This is what I get
> ARMmite MMBasic Version 5.07.00b10
Copyright 2011-2020 Geoff Graham
Copyright 2016-2020 Peter Mather
> memory
Flash:
 17K (12%) Program (500 lines)
115K (88%) Free
RAM:
  0K ( 0%) General
114K (100%) Free
Andrew_G
Posted: 03:20am 11 Apr 2021
Lizby,
Thank you so much for that. Very reassuring.
I don't know why, but I keep on worrying that I have broken the poor little MMite. In fact my chip wastage is quite low.
Now I can go looking for the reason the F4 is running out of memory.
Cheers,
Andrew
Andrew_G
Posted: 05:25am 11 Apr 2021
Very strange!
The line:
Circle 602, 255, 154, 3,,RGB(red)
causes an "Error : Not enough memory" within my spaghetti.
With just the following snippet - after about 10 loops it errors out too:
 Memory
 do
   memory
   pause 10000
 loop
End
It appears to be the line width of 3 causing the problem (a fix for me is to draw 3 circles). But this looks like a question for Peter?
Cheers,
Andrew
(apologies to any who read this while I was editing it to add more information)
Edited 2021-04-11 15:46 by Andrew_G
Posted: 07:12am 11 Apr 2021
Same thing on the standard 320 x 240 LCD.
do :memory :circle 160, 120, 100,5,1,rgb(green): loop
gives:-
Flash:
  1K ( 1%) Program (15 lines)
131K (99%) Free
RAM:
 55K (48%) General
 59K (52%) Free
Flash:
131K (99%) Free
RAM:
 61K (53%) General
 53K (47%) Free
Flash:
131K (99%) Free
RAM:
 68K (59%) General
 46K (41%) Free
Flash:
131K (99%) Free
RAM:
100K (88%) General
 14K (12%) Free
Flash:
131K (99%) Free
RAM:
107K (93%) General
  7K ( 7%) Free
Flash:
131K (99%) Free
RAM:
113K (99%) General
  1K ( 1%) Free
Andrew_G
Posted: 07:17am 11 Apr 2021
So its out of our league. (F4 or MMBasic?)
How do we summon Peter when we need him. Is there a spotlight we can shine on a cloud in the UK?
Cheers,
Andrew
Posted: 07:34am 11 Apr 2021
Thanks for the report. Easy fix. Will post on main thread.
Andrew_G
Posted: 07:38am 11 Apr 2021
Thanks Peter - I hope you don't mind being demeaned by a reference to Batman!
You are a much more omnipresent superhero . . .
Andrew
It is said that if you place a Microchip Backpack on the floor and walk round it 3 times while reading the Copyright section of the Micromite User Manual then HE will take on HIS earthly form.
Or it might just be in my deranged imagination...
