Local Time 20:44 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD card - Use of Eastrising 9" LCD's instead of F4's
Andrew_G
Posted: 12:46am 10 Apr 2021
G'day all,
Is it possible to use the SD card on an Eastrising 9" LCD instead of that on the ArmmiteF4?
(The F4 one works a treat but the ER's one is positioned better for access.)
Cheers,
Andrew
Posted: 06:50am 10 Apr 2021
No: LCD SD cards are wired for SPI. The F4 uses SDIO
Chopperp
Posted: 10:53am 10 Apr 2021
There are a number of micro USB to micro USB M to F extension cables around.
I got a couple from Core Electronics (I think). Bit flimsy though & fairly long.
Brian.
ChopperP
Andrew_G
Posted: 11:43am 10 Apr 2021
Thanks Peter.
Cheers,
Andrew
