Local Time 20:45 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question on Drawing over an Image
William Leue
Posted: 10:02pm 08 Apr 2021
I have some puzzling behavior going on in a program I am writing, and I am hoping somebody can help.
If I do this simple thing:
Mode 1,12
Load PNG "blah.png"
line 0, 0, 799, 599,, RGB(RED)
everything works as I expect; that is, the image is shown and then the red line is drawn on top of the image. (I am using 12-bit color because I will eventually want to draw translucent stuff on top of the image.)
However, if I do this instead:
Mode 1,12
page write 1
load PNG "blah.png"
page write 0
page copy 1 to 0, B
The line does NOT appear on top of the image! (My actual code is more complicated but this is the essence.)
There must be something magic about the page copy but I can't imagine what it is.
-Bill
vegipete
Posted: 10:06pm 08 Apr 2021
The line is on top of the image on page 0. However, page 1 is on top of page 0.
Edited 2021-04-09 08:06 by vegipete
Posted: 10:47pm 08 Apr 2021
From my help pages (which came from Peter):
  Quote  The display always shows the contents of page 0 (16-bit and 8-bit) and pages 0 and 1 (12-bit). Use PAGE WRITE and PAGE COPY to avoid flashing and tearing artefacts.
For 12-bit colour depth page 0 is the lower level and page 1 the upper so the stack is: background, page 0, page 1 with each one overwriting the previous in turn as defined by the transparency values of each individual pixel.
Mode 1,12
page write 0
load PNG "blah.png"
page write 1
do:loop until inkey$ <> ""
William Leue
Posted: 11:28pm 08 Apr 2021
Thanks! I always thought pages 1 and 2 were totally offscreen. That explains a lot!
-Bill
William Leue
Posted: 12:50am 09 Apr 2021
It works great, once I changed which page was which. Thanks much, vegipete and TassyJim, you guys certainly deserve your Guru labels!
-Bill
