Forum Index : Microcontroller and PC projects : Armmite F4: I2C OPEN resets DI, DO status of I2C2 SDA pin
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3881 |
> new > setpin 48,dout > setpin 47,dout > pin(48)=1 > pin(47)=1 > I2C open 100,1000 > pin(48)=0 Error : Pin | is not an output > pin(47)=0 SDA (48) is affected but not SCL (47) (Also, can the error message provide the pin # instead of "|"?) PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11891 |
Please try the attached ArmmiteF407.zip Edited 2021-04-09 04:45 by matherp |
Perfect. Thank you. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
