Local Time 20:58 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Dec Command missing
Archimedes5000
Posted: 09:52am 07 Apr 2021
CMM2 V5.06
It doesn't matter that much, but I found the INC command and then searched for DEC as well. Doesn't he seem to be there? Possibly to be taken into account in a future firmware?
Greetings Axel
Posted: 09:59am 07 Apr 2021
"INC x,-1" is the way to do it. The value can be positive or negative so you can DEC by 5 using "INC x,-5" etc. It looks a little odd but it's flexible, it works and it only needs one entry in the commands table. :)
jirsoft
Posted: 10:13am 07 Apr 2021
The advantage is you can use it without IF condition:
INC variable, step*(variable < upperLimit)
INC variable, -step*(variable > lowerLimit)
INC i,(i<10)
will for example add 1 to i but maximal up to 10
Jiri
Posted: 11:00am 07 Apr 2021
why INC ?
i=i+(i<10)
jirsoft
Posted: 11:02am 07 Apr 2021
If I understood it correctly, INC should be faster...
If correctly programmed, after evaluation of right side to 0 nothing happens. In your case will be still i=i
Edited 2021-04-07 21:04 by jirsoft
Jiri
Tinine
Posted: 03:07pm 07 Apr 2021
  Volhout said  why INC ?
i=i+(i<10)
Very cool
RetroJoe
Posted: 03:38pm 07 Apr 2021
There was a thread on INC when Peter first introduced it.
It is intended to accelerate simple increments and decrements for counter variables, as the interpreter knows to take a more direct evaluation path versus parsing a generic algebraic expression.
It is measurably faster, but I agree with the semantic purists on this - "incrementing" by a negative number is counterintuitive, and the "missing" DEC command makes the language less orthogonal and readable.
I expect Peter made this decision to save a few bytes somewhere, but creeping inelegance is a slippery syntactical slope. Put another way, "symmetry is beauty".
Edited 2021-04-08 02:01 by RetroJoe
Enjoy Every Sandwich / Joe P.
