Local Time 10:51 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - function$ for CALL somehow limited, bug?
jirsoft
Posted: 01:52pm 04 Apr 2021
I used in program for programming challenge CALL command for very simple and effective key->routine selector  and found some (for me) strange behaviour:
This code is working
key$= "abc"
func$="nabc"
DO
 fun$ = MID$(func$, INSTR(keys$, LCASE$(INKEY$)) + 1, 1)
 CALL fun$
LOOP
END
SUB n 'empty function, needed for no key press
END SUB
SUB a
 ?a
END SUB
SUB b
 ?b
END SUB
SUB c
 ?c
END SUB
But when I put it all into CALL
DO
 CALL MID$(func$, INSTR(keys$, LCASE$(INKEY$)) + 1, 1)
LOOP
I will get Argument list error. But some primitive string handling are working properly. Is it a bug?
Jiri
Posted: 04:32pm 04 Apr 2021
  Quote  But when I put it all into CALL
DO
LOOP
Check the manual. I'm surprised the first version works - certainly not by design
Posted: 04:45pm 04 Apr 2021
I'm missing something, in what way does the manual entry suggest that this wouldn't work?
Posted: 04:47pm 04 Apr 2021
  Quote  This is an efficient way of programmatically calling user defined subroutines
Posted: 04:58pm 04 Apr 2021
Still not getting it Peter: n, a, b & c are USER defined subroutines.
jirsoft
Posted: 05:13pm 04 Apr 2021
I don't see here anything wrong
CALL fun$
When it will be
fun$ = "MID$(func$, INSTR(keys$, LCASE$(INKEY$)) + 1, 1)"
CALL fun$
then it will be calling built-in function.
But interesting is, when I will change it to
key$= "abc"
func$="nabc"
DO
 CALL "f" + fun$
LOOP
END
SUB fn 'empty function, needed for no key press
END SUB
SUB fa
 ?a
END SUB
SUB fb
 ?b
END SUB
SUB fc
 ?c
END SUB
Then it will work OK, so some calculations are allowed in CALL...
Jiri
Posted: 05:18pm 04 Apr 2021
Yes but MID$ isn't so
can't work. Everything after the CALL command is interpreted as though it was normal inline code but you can't have two in-built command tokens in a row
You are correct of course about CALL fun$ that is what it is designed for - me being stupid
Posted: 05:19pm 04 Apr 2021
EDIT: written before Peter's previous response.
My guess is that the parser thinks one of the commas in MID$ or INSTR is a parameter separator in the CALL command.
But I could be talking tripe,
Edited 2021-04-05 03:22 by thwill
jirsoft
Posted: 05:34pm 04 Apr 2021
Thanks Peter,
clear with more than one token. In normal life (not one page challenge  ) one row more isn't problem...
I still think it's pretty effective way to select routines depending on key, you have just one condition, all function names need to have exact same length. Maximum length of func$ can be solved with LONGSTRING if needed.
Selector with 5 characters per function:
key$= "abc"
func$="emptyFUNCaFUNCbFUNCc"
DO
      fun$ = MID$(func$, 5*INSTR(keys$, LCASE$(INKEY$)) + 1, 5)
      CALL fun$
LOOP
SUB empty 'empty function, needed for no key press
END SUB
SUB FUNCa
      ?a
END SUB
SUB FUNCb
      ?b
END SUB
SUB FUNCc
      ?c
END SUB
Edited 2021-04-05 03:36 by jirsoft
Jiri
