Local Time 11:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Question: ADC on PLAY SOUND output?
RetroJoe
Posted: 03:12pm 30 Mar 2021
Is there a way to digitize the output of the PLAY SOUND command using the ADC command?
E.g. is the L & R output voltage of the PLAY SOUND  command available on the I/O pins so they can be looped back for reading with the ADC command? Maybe there is a way to perform the loopback in software?
In either case, would this operation be "non-blocking" l.e.will the ADC command work properly while PLAY SOUND is running?
The use case is to create a little oscilloscope display of the audio waveform that is playing. Any guidance would be appreciated!
Enjoy Every Sandwich / Joe P.
Posted: 05:19pm 30 Mar 2021
  Quote  Is there a way to digitize the output of the PLAY SOUND command using the ADC command?
Like this?
The code is  on TBS here
Edited 2021-03-31 03:27 by matherp
RetroJoe
Posted: 05:39pm 30 Mar 2021
Peter, thanks - almost like that, but simpler (basic waveforms via PLAY SOUND instead of MP3 playback, and a time series display instead of frequency domain).
But, yeah, pretty much the desired effect - the FFT will be a nice "flourish" :)
