Local Time 11:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Windows updates for March use a selective installation.
Paul_L
Posted: 09:07pm 29 Mar 2021
If you're running Windows 10 2004 or 20H2 skip the March 9th updates and install the March 18th KB5001649 but if you're running Windows 10 1909 install KB5001648.
Both are cumulative updates so you will never need the earlier ones.
If they are not offered to you automatically you can download them from https://www.catalog.update.microsoft.com/Home.aspx which provides a search box. Be careful which update you download ... it offers versions for x64 Server, x64 Standalone, x86, ARM64 Server, and ARM64 Standalone.
If you're still running Windows 8.1 or 7 good luck because the updates are not cumulative.
Are you sufficiently confused yet? If not check out https://www.computerworld.com/article/3613419/patch-tuesday-recap-this-month-an-ides-of-march-update.html
Paul in NY
