Local Time 11:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: minor issue with play wav IRQ and workaround
epsilon
Posted: 07:14am 24 Mar 2021
Here's a minor issue I came across on CMM2:
My program uses PLAY WAV with an interrupt routine that's called when the file finised playing, like this:
PLAY WAV sound_curFile$, Sound_play_int
When the program ends, the device is left in a somewhat confused state. E.g. when I launch xedit, I get this error:
Error in line 877: Unknown command
This is line 877:
SETTICK CURSOR_BLINK_PERIOD%, blinkCursorInt, 1
To clear the condition, I just do this:
PLAY WAV ""
PLAY STOP
i.e. the trick is to kick off a PLAY WAV _without_ an interrupt routine. After that, everything goes back to normal.
Epsilon CMM2 projects
