Local Time 11:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LONGSTRING TRIM, maximum clippable length is LLEN - 1
jirsoft
Posted: 06:53pm 20 Mar 2021
I'm working right now with UDP communication with ESP and using LONGSTRINGs. I'm filling LONGSTRING with complete UDP buffer and after the packet is received, I need to read LF separated strings from it.
After read I need to remove this parts from LONGSTRING, it works all the way except last one. I'm getting error, that maximum clippable part is LLEN - 1. Can this be in the future FW changed, so I can TRIM complete LONGSTRING? It shouldn't affect any existing program but increase effectivity.
LF = STR$(10)
DO WHILE LLEN(buf()) > 0
 bufLen = LINSTR(buf(), LF)
 IF bufLen > 0 THEN
   part = LGETSTR$(buf(), 1, bufLen - 1)
   LONGSTRING TRIM buf(), bufLen 'this works up to last part, then error
 ENDIF
LOOP
now I have modified it to
LF = STR$(10)
 IF bufLen > 0 THEN
   IF bufLen < LLEN(buf()) THEN
   ELSE
     LONGSTRING CLEAR buf()
   ENDIF
 ENDIF
LOOP
Jiri
