Local Time 21:12 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite F4 GUI GAUGE Not OK on Font 6
Chopperp
Posted: 08:35am 19 Mar 2021
Hi
I found that on Font #6 on the standard display panel, the Units$ value was not being printed. OK on Font 5 & below.
Test code below to show the differences between fonts 5 & 6.
 'mm.ver 5.0601
 option explicit
 const DBlue = rgb(0,0,128)    'define LCD colour.
 colour rgb(green), DBlue
 backlight 50                 'set backlight brightness
 box 0, 0, MM.HRes - 1, MM.VRes - 1, 1, dblue, DBlue 'Outside box
do
   font 5,1
   gui gauge #1, mm.hres/2, mm.vres/2, mm.vres/2.2, rgb(yellow), dblue, 0, 1500, 0, "RPM", rgb(green),1000,rgb(yellow),1200, rgb(red), 1500
   ctrlval(1) = 100
   pause 1000
   gui delete #1
   font 6,1
   ctrlval(1) = 100
   pause 2000
   gui delete #1
 loop
Hopefully I am missing something
Brian
ChopperP
Posted: 08:40am 19 Mar 2021
  Quote  Hopefully I am missing something
Yes: all the characters except 0-9, decimal point, space, + and -, degree and colon. Same as the MM+ and CMM2
Chopperp
Posted: 08:48am 19 Mar 2021
Ah, thanks.
Font 4,2 works.
Edited 2021-03-19 18:52 by Chopperp
ChopperP
Chopperp
Posted: 12:30pm 19 Mar 2021
OK, probably doing something else wrong.
In the code below, the Digital display colours follow the gauge colours when the values are increasing as expected.
However, when the values are decreasing, it takes two goes with different values (second one lower) in the same alarm region before the text colours change to match the gauge.
Gauge Parameters
Min = 0
Max = 1500
0 - 999 = Green
Yellow => 1000
Red => 1200
  'mm.ver 5.0601
 option explicit
   font 4,2
   gui gauge #1, mm.hres/2, mm.vres/2, mm.vres/2.2, rgb(white), dblue, 0, 1500, 0, "RPM", rgb(green),1000,rgb(yellow),1200, rgb(red), 1500
 do
   ctrlval(1) = 300    'text green   = OK
   pause 2000
   ctrlval(1) = 1050   'text yellow  = OK
   pause 2000
   ctrlval(1) = 1350   'text red     = OK
   pause 2000
   ctrlval(1) = 1150   'text still red = Not OK
   pause 2000
   pause 2000
   pause 2000
   ctrlval(1) = 500    'text still yellow = Not OK
   pause 2000
 loop
Brian
ChopperP
Posted: 01:34pm 19 Mar 2021
5.07.b5 behaves the same
Posted: 02:04pm 19 Mar 2021
Can anyone check this on a MM+?
AFAIK the GUI code is identical to the latest MM+ release and not something I've had any involvement with or have any knowledge of
panky
Posted: 04:27am 20 Mar 2021
On an Explore 100 running 5.05.03, works as shown in example above, ie. the first change down does not reflect a colour change. One for Geoff?
Doug.
Chopperp
Posted: 11:37am 20 Mar 2021
Thanks Peter & Doug
It looks like there won't be a quick fix.
Did a very rough temporary solution/work-around as a proof of concept which will work for me for the time being.
Just overriding the normal digits (using font #6) & inserting the units (RPM) using font #5 with the colours selected by a SELECT CASE routine according to the value of CTRLVAL(1).
 'mm.ver 5.0601
 option explicit
 dim Text_Colour
   font 6,1
   gui gauge #1, mm.hres/2, mm.vres/2, mm.vres/2.1, rgb(white), dblue, 0, 1500, 0, "RPM", rgb(green),1000,rgb(yellow),1200, rgb(red), 1500
 do
   Digits_Print
   pause 1000
   Digits_Print
   pause 1000
   Digits_Print
   pause 1000
   Digits_Print
   pause 1000
   Digits_Print
   pause 1000
   Digits_Print
   pause 1000
 loop
 sub Digits_Print
   select case ctrlval(1)
     case < 1000
       Text_Colour = rgb(green)
     case < 1200
       Text_Colour = rgb(Yellow)
     case else
       Text_Colour = rgb(red)
   end select
       text mm.hres/2 , mm.vres/2, Str$(ctrlval(1)), "CB", 6, 1, Text_Colour
       text mm.hres/2 , 170, "RPM", "CB", 5, 1, Text_Colour
 end sub
Brian
ChopperP
Posted: 08:37am 21 Mar 2021
Geoff has fixed this and I've included the fix in the ArmmiteF4 5.07.00b9 release
Chopperp
Posted: 10:25am 21 Mar 2021
That was quick. Thanks.
I wasn't sure what the procedure was for problems like this. Obviously Geoff was notified.
ChopperP
Chopperp
Posted: 07:35am 22 Mar 2021
Updated & confirmed fixed.
Thanks again Geoff & Peter
ChopperP
