Local Time 11:19 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Program memory taken by CSUBs
Posted: 11:16am 15 Mar 2021
This is not a complaint merely an RFI.
It looks like the ASCII/HEX text of a CSUB definition is maintained in Program memory even though it is presumably never referenced after the "flashing magic" has happened, e.g. for SPForth:
> memory
Program:
 90K (17%) Program (1059 lines)   <-- primarily the CSUB text
 29K ( 5%) 1 Embedded C Routine
397K (78%) Free
Is there any particular reason it has to be kept around, once it has been converted to native code couldn't the in-flash copy of the BASIC program just store blank lines in its place? Perhaps there is nothing to gain because you would be beyond the point where that extra Program Memory was useful.
