Local Time 02:22 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Forth - proof of concept
     Page 1 of 3
Posted: 03:18pm 10 Mar 2021
Hi folks, after 3 weeks of hiding from the wife and kids  :
Option Explicit On
Option Base 0
Option Default None
#include "spforth.inc"
calculate_in_basic(5000)
Print
Print
calculate_in_forth(5000)
End
Sub calculate_in_basic(limit%)
 Local n%, k%, t%
 Local flags%(limit%)
 t% = Timer
 For n% = 2 To Sqr(limit%)
   If flags%(n%) = 0 Then
     For k% = n%*n% To limit% Step n%
       flags%(k%) = 1
     Next k%
   EndIf
 Next n%
 Print "Primes:";
 For n% = 2 To limit%
   If flags%(n%) = 0 Then Print n%;
 Next n%
 t% = Timer - t%
 Print
 Print
 Print "TOTAL:" (t% / 1000) " s"
End Sub
Sub calculate_in_forth(limit%)
 Local t_init%
 Local t_compile%
 Local t_execute%
 Local mem_size% = 100 * 1024 ' 100 K
 Local memory%(mem_size% \ 8) ' Each integer is 8 bytes
 t_init% = Timer
 spforth(memory%(), mem_size%, "");
 t_init% = Timer - t_init%
 Print
 Print
 t_compile% = Timer
 spforth(memory%(), 0, ": prime? here @ + c@ 0= ;")
 spforth(memory%(), 0, ": composite! here @ + 1 swap c! ;")
 spforth(memory%(), 0, ": sieve")
 spforth(memory%(), 0, "  here @ over erase")
 spforth(memory%(), 0, "  2")
 spforth(memory%(), 0, "  begin")
 spforth(memory%(), 0, "    2dup dup * >")
 spforth(memory%(), 0, "  while")
 spforth(memory%(), 0, "    dup prime? if")
 spforth(memory%(), 0, "      2dup dup * do")
 spforth(memory%(), 0, "        i composite!")
 spforth(memory%(), 0, "      dup +loop")
 spforth(memory%(), 0, "    then")
 spforth(memory%(), 0, "    1+")
 spforth(memory%(), 0, "  repeat")
 spforth(memory%(), 0, "  drop")
 spforth(memory%(), 0, "  ." + Chr$(34) + " Primes: " + Chr$(34) + " 2 do i prime? if i . then loop ;")
 t_compile% = Timer - t_compile%
 t_execute% = Timer
 spforth(memory%(), 0, Str$(limit%) + " sieve")
 t_execute% = Timer - t_execute%
 Print
 Print
 Print "Initialisation time:" t_init% / 1000 " s"
 Print "Compile time:       " t_compile% / 1000 " s"
 Print "Execute time:       " t_execute% / 1000 " s"
 Print "TOTAL:              " (t_init% + t_compile% + t_execute%) / 1000 " s"
End Sub
Of course you will need the ridiculous CSUB (compiled with -O3) contained within this file too: spforth.zip. Is there a prize for largest CSUB? do I win it?
Output on a 400 MHz CMM2:
> run "forth_test.bas"
Primes: 2 3 5 7 11 13 17 19 23 29 31 37 41 43 47 53 59 61 67 71 73 79 83 89 97 101 103 107 109 113 127 131 137 139 149 151 157 163 167 173 179 181 191 193 197 199 211 223 227 229 233 239 241 251 257 263 269 271 277 281 283 293 307 311 313 317 331 337 347 349 353 359 367 373 379 383 389 397 401 409 419 421 431 433 439 443 449 457 461 463 467 479 487 491 499 503 509 521 523 541 547 557 563 569 571 577 587 593 599 601 607 613 617 619 631 641 643 647 653 659 661 673 677 683 691 701 709 719 727 733 739 743 751 757 761 769 773 787 797 809 811 821 823 827 829 839 853 857 859 863 877 881 883 887 907 911 919 929 937 941 947 953 967 971 977 983 991 997 1009 1013 1019 1021 1031 1033 1039 1049 1051 1061 1063 1069 1087 1091 1093 1097 1103 1109 1117 1123 1129 1151 1153 1163 1171 1181 1187 1193 1201 1213 1217 1223 1229 1231 1237 1249 1259 1277 1279 1283 1289 1291 1297 1301 1303 1307 1319 1321 1327 1361 1367 1373 1381 1399 1409 1423 1427 1429 1433 1439 1447 1451 1453 1459 1471 1481 1483 1487 1489 1493 1499 1511 1523 1531 1543 1549 1553 1559 1567 1571 1579 1583 1597 1601 1607 1609 1613 1619 1621 1627 1637 1657 1663 1667 1669 1693 1697 1699 1709 1721 1723 1733 1741 1747 1753 1759 1777 1783 1787 1789 1801 1811 1823 1831 1847 1861 1867 1871 1873 1877 1879 1889 1901 1907 1913 1931 1933 1949 1951 1973 1979 1987 1993 1997 1999 2003 2011 2017 2027 2029 2039 2053 2063 2069 2081 2083 2087 2089 2099 2111 2113 2129 2131 2137 2141 2143 2153 2161 2179 2203 2207 2213 2221 2237 2239 2243 2251 2267 2269 2273 2281 2287 2293 2297 2309 2311 2333 2339 2341 2347 2351 2357 2371 2377 2381 2383 2389 2393 2399 2411 2417 2423 2437 2441 2447 2459 2467 2473 2477 2503 2521 2531 2539 2543 2549 2551 2557 2579 2591 2593 2609 2617 2621 2633 2647 2657 2659 2663 2671 2677 2683 2687 2689 2693 2699 2707 2711 2713 2719 2729 2731 2741 2749 2753 2767 2777 2789 2791 2797 2801 2803 2819 2833 2837 2843 2851 2857 2861 2879 2887 2897 2903 2909 2917 2927 2939 2953 2957 2963 2969 2971 2999 3001 3011 3019 3023 3037 3041 3049 3061 3067 3079 3083 3089 3109 3119 3121 3137 3163 3167 3169 3181 3187 3191 3203 3209 3217 3221 3229 3251 3253 3257 3259 3271 3299 3301 3307 3313 3319 3323 3329 3331 3343 3347 3359 3361 3371 3373 3389 3391 3407 3413 3433 3449 3457 3461 3463 3467 3469 3491 3499 3511 3517 3527 3529 3533 3539 3541 3547 3557 3559 3571 3581 3583 3593 3607 3613 3617 3623 3631 3637 3643 3659 3671 3673 3677 3691 3697 3701 3709 3719 3727 3733 3739 3761 3767 3769 3779 3793 3797 3803 3821 3823 3833 3847 3851 3853 3863 3877 3881 3889 3907 3911 3917 3919 3923 3929 3931 3943 3947 3967 3989 4001 4003 4007 4013 4019 4021 4027 4049 4051 4057 4073 4079 4091 4093 4099 4111 4127 4129 4133 4139 4153 4157 4159 4177 4201 4211 4217 4219 4229 4231 4241 4243 4253 4259 4261 4271 4273 4283 4289 4297 4327 4337 4339 4349 4357 4363 4373 4391 4397 4409 4421 4423 4441 4447 4451 4457 4463 4481 4483 4493 4507 4513 4517 4519 4523 4547 4549 4561 4567 4583 4591 4597 4603 4621 4637 4639 4643 4649 4651 4657 4663 4673 4679 4691 4703 4721 4723 4729 4733 4751 4759 4783 4787 4789 4793 4799 4801 4813 4817 4831 4861 4871 4877 4889 4903 4909 4919 4931 4933 4937 4943 4951 4957 4967 4969 4973 4987 4993 4999
TOTAL: 0.172 s
SPFORTH v0.1.0
22295 CELLS REMAINING
OK
Initialisation time: 0.01 s
Compile time:        0.001 s
Execute time:        0.13 s
TOTAL:               0.141 s
If I'm completely honest then I'm a bit disappointed that the Forth isn't significantly faster. HOWEVER currently the BEGIN, WHILE, IF, THEN, DO, +LOOP, etc. keywords are all defined in terms of lower-level Forth words. If I implement them in C instead then I will probably get a measurable performance improvement.
I'm going for a lie down.
Edited 2021-03-11 01:29 by thwill
Posted: 03:57pm 10 Mar 2021
WOW!!!
Posted: 04:06pm 10 Mar 2021
I should have said in my first post that this isn't 100% my own work, I ported an x86 assembler Forth implementation https://github.com/nornagon/jonesforth to "C" and then just had to debug it and solve the problems with CMM2/CSUB compatibility.
Before I discovered jonesforth I did get 25% of the way there on my own and then had to decide between porting someone else's work and getting it done ASAP, or doing it all myself and not having it until the summer - if then, I chose the former but am glad I made a start on my own.
Edited 2021-03-11 02:19 by thwill
Posted: 04:09pm 10 Mar 2021
  matherp said  WOW!!!
You say that, but give me a few weeks and I'll probably be asking all sorts of questions about ARMCFunctions.h - and for all sorts of additions. Currently it just uses getConsole(), putConsole() and RoutineChecks().
Edited 2021-03-11 02:10 by thwill
Plasmamac
Posted: 03:01am 11 Mar 2021
Really a WOW !
Plasma
Posted: 05:04pm 11 Mar 2021
A couple of minor tweaks and things are looking better:
> run
Primes: ... output deleted for brevity...
TOTAL: 0.16 s
SPFORTH v0.1.0
22294 CELLS REMAINING
OK
Initialisation time: 0.009 s
Execute time:        0.094 s
TOTAL:               0.104 s
So the Forth version is now a good 50% faster than the MMBasic version and I haven't even broken out the "bug guns" yet.
Note the MMBasic version is faster than my initial measurement too since I removed the unnecessary variables from the NEXT statements.
Edited 2021-03-12 03:08 by thwill
Posted: 05:09pm 11 Mar 2021
Are you going to eventually allow reading arbitrary forth from file?
Posted: 05:18pm 11 Mar 2021
  matherp said  Are you going to eventually allow reading arbitrary forth from file?
You can do it now. Use MMBasic to read lines from the file and call spforth() with them one at a time. You're only paying the cost for this once whilst they are compiled.
Now if you added a construct to the pre-processor equivalent to C's:
#if 0
ignore this,
and this,
and this
#endif
Then I could read Forth from the .BAS file and we have "inline assembler" ... I think it should be possible to get Forth at least twice as fast as MMBasic if not more.
Posted: 06:04pm 11 Mar 2021
  Quote  Now if you added a construct to the pre-processor equivalent to C's:
Not a pre-processor issue - it would need to somehow skip the tokenising which is core MMbasic.
In essence you are asking for a data statement without the DATA command. I think something like a CSUB block but allowing ascii could work as this could be generally useful. I'll have a think. Of course you need to do better then a 0.94/1.6 ratio in performance terms to make it worthwhile
Posted: 07:53pm 11 Mar 2021
I've managed to "acquire" a couple of command slots so my initial thoughts are:
DEFINEDATA n
ascii
more ascii
as much ascii as you like
END DEFINEDATA
? MM.INFO(DATA ADDRESS n) ' gives the address in memory of the start of the ascii data block number n
? MM.INFO(DATA SIZE n) ' gives the length in bytes of the data block number n
Limitations: You can't have "END DEFINEDATA" in the ascii for obvious reasons. You also can't use the C "or" character in the ascii (|)
This is a lot of work as I have to stop the firmware interfering with the ascii in quite a few places so I need to know if it will be worthwhile.
Edited 2021-03-12 05:55 by matherp
Posted: 08:00pm 11 Mar 2021
Thanks Peter,
As far as Forth goes I should have all the easy and medium difficulty performance gains worked through within a couple of weeks so you can make a judgement call then. Beyond that there would be converting some of it directly to ARM Thumb and that's a much longer term prospect with less certainty of success.
jirsoft
Posted: 09:14pm 11 Mar 2021
  matherp said  I've managed to "acquire" a couple of command slots so my initial thoughts are:
DEFINEDATA n
ascii
more ascii
END DEFINEDATA
Hi Peter,
just an stupid idea, couldn't you use something similar to ON ERROR SKIP?
DEFINEDATA n, 4 (#of lines with data)
ascii '1. line
more ascii '2. line
as much ascii as you like '3. line
END DEFINEDATA '4. line?
Of course, END DEFINEDATA is now not so important...
Jiri
Posted: 09:39pm 11 Mar 2021
Charles Moore will be impressed.
I still have my copy of Leo Brodie's "Starting Forth"
But I notice that it is available as a PDF from
https://www.forth.com/starting-forth/
The followup book, "Thinking Forth" is also available as a PDF.
I enjoyed playing with Forth all those years ago.
Time to see if the magic is still there.
OA47
Posted: 09:43pm 11 Mar 2021
@ Jim, From the front cover, it looks like cloud computing is not as new as I thought.
OA47
Posted: 09:52pm 11 Mar 2021
  OA47 said  @ Jim, From the front cover, it looks like cloud computing is not as new as I thought.
OA47
No, that's the dust cloud from pulling the book of the shelf.
I should point out that the image is from the net, my copy is a bit more 'used' than depicted.
CircuitGizmos
Posted: 09:54pm 11 Mar 2021
DEFINEDATA n
ascii
more ascii
END DEFINEDATA
I've done hex with CSUB. Works well but seems likely to be obscure to newbies and is inflexible.
Would it be reasonable to support different data types?
DEFINEDATA n
ascii
END DEFINEDATA
DEFINEDATA n AS BYTE
 00 0E 37 A9 40 04 00 CC
END DEFINEDATA
DEFINEDATA n AS WORD
 000E 37A9 4004 00CC
END DEFINEDATA
And (dangerously) store it in FLASH? Caveat emptor/programmer
DEFINEDATA n AS WORD at &H081C0000
 000E 37A9 4004 00CC
END DEFINEDATA
vegipete
Posted: 10:01pm 11 Mar 2021
  matherp said  DEFINEDATA n
ascii
more ascii
END DEFINEDATA
What is ascii data? Only 7 bit values from 32 to 127, not including 124?
Full 8 bit binary data would be useful for embedding graphics, sprites and sound.
(And machine code for a 6502 simulator.  ;-)
CircuitGizmos
Posted: 10:04pm 11 Mar 2021
 000E 37A9 4004 00CC
END DEFINEDATA
Well, actually, supplying a CSUB for FLASH write/erase would be better than adding this to the core language.
And why the C "or" ( | ) out of curiosity?
Edited 2021-03-12 08:06 by CircuitGizmos
Posted: 10:48pm 11 Mar 2021
  Quote  just an stupid idea, couldn't you use something similar to ON ERROR SKIP?
No for the reason explained above - the code would be tokenised and therefore changed
  Quote  Full 8 bit binary data would be useful for embedding graphics, sprites and sound.
  Quote  Would it be reasonable to support different data types?
You can do this already with a FONT or CSUB. Obscure ? yes, but identical in function so no reason to add
  Quote  Well, actually, supplying a CSUB for FLASH write/erase would be better than adding this to the core language.
Flash can only be erased in 128Kb chunks - far too coarse to be of any use
  Quote  And why the C "or" ( | ) out of curiosity?
I use it internally for line number error handling and include files
Posted: 11:38pm 11 Mar 2021
  TassyJim said  I still have my copy of Leo Brodie's "Starting Forth"
I have a spiral bound printed PDF of that book and the 35th Anniversary Edition reproduction of the "Jupiter ACE (FORTH Programming)" manual even as I type.
  Quote  The followup book, "Thinking Forth" is also available as a PDF.
Thankyou, I will snag and print a copy.
  Quote  I enjoyed playing with Forth all those years ago.
Might want to give it a few weeks, it's just a "proof of concept", now I need to find out if it can be made fast enough to "matter" and then worry about filling in the gaps and improving its compliance with Brodie's books.
Edited 2021-03-12 10:12 by thwill
     Page 1 of 3
